Home > Maintenance & Mods (L322) > RHD passenger footwell damp, where to check?
conor
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
So guys,
I promise this is the final hurdle to fix before I start driving this baby! I don't want to drive it with an active leak into the cabin.
Anyway, I noticed the passenger footwell has a damp carpet, with a little mould from sitting around for a while. It's not sopping but damp..
I'm just trying to figure out the places to check. Currently I have:
* Air conditioning pipes x2 underneath.
* Drainage points on roof, around sunroof. - I can't open the sunroof yet, can I check them with it closed?
Thanks
Conor (07) 2007 3.6 TDV8 L322 - 135k miles.
(05) 2006 MY Supercharged L322 - Zambezi Silver on Jet Black - 162k miles.
** Smiles per gallon - never forget **
Post #621014 22nd Jan 2022 11:28pm
mjdronfield
As you recon, I’d say sunroof drain or heater matrix/ac as a starter.
Think folk push strimmer line down the holes with the sunroof open… make sure drains are all clear.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #621021 23rd Jan 2022 12:33am
conor
Brill thanks.. now to get the sun roof open.
Need to check the fuse and hope it's just that.. (07) 2007 3.6 TDV8 L322 - 135k miles.
Post #621022 23rd Jan 2022 12:50am
JCW
May be worth checking the rear screen washer pipe which runs around the passenger footwell area from the lower bulkhead - if you remove the plastic trim panel you can locate and check the pipe behind the carpet.
On a previous L322, when my rear washer check valve got blocked, the pipe leaked washer fluid into the passenger footwell when using the rear wash / wipe.
Post #621034 23rd Jan 2022 8:10am
