Home > Technical (L322) > '11 4.4 TDV8 - Coolant Leak
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
It appears I have a coolant leak from my 4.4 TDV8.
Haven't been able to see exactly where it is leaking from but when I was working on the brakes recently a small puddle formed towards the back of the engine.
Any suggestions as to where I should start looking?
Is this likely to be a difficult/costly fix?
Post #621008 22nd Jan 2022 10:54pm
JayGee
Any oil or coolant leak nr the back of these engines and the first suspect has to be the oil cooler seals. Check your coolant expansion tank for oil contamination as well. 2012 TDV8 Vogue (L322)
Post #621043 23rd Jan 2022 9:32am
DrRob
Engine cover off, bonnet in service mode, remove pollen box with 2 nuts, grab a step and peer down back of engine and see if anything untoward going on around the oil cooler in the V. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #621056 23rd Jan 2022 10:16am
