![]() | Home > Maintenance & Mods (L322) > LR set to recall all 2011MY FFRR's for new AGM battery |
| johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519
But Scarey - the 4.4 V8 isn't in production in 2011... |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
i thought that as well but i went by his car profile and the fact that rambles hadn't noticed it working or in the handbook.... ... - .- -.
there's a massive thread here that might go a little way of explaining the FBH and how it works, not sure whether its applicable to the 2011 versions though..
Sorry I assume you would have selected the 'TDV8' option on the forum like other owners including myself. Yes FBH is standard for Diesel engines but the 4.4 V8 engine choice you have selected refers to the Petrol engine that ran until around 2007. The FBH is programmed in that way and if it didn't add anything to the vehicle then simply Land Rover wouldn't have it doing that. In theory a second small 'engine' is running in addition to heat the coolant fluid and therefore help the car reach to its most efficient. Rambles - refer to the wiki which Scarey has pointed you towards. At the bottom there is a section on Td6 vehicles and the same process happens with the TDV8 engine. |
| Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850
The TDV8 option is also the same option for the 2010 model. Which was a 3.6.
The car is doing what it's supposed to do. It will shut down the radio to conserve battery. Porsche, BMW, MINI all do the same. The FBH will of course operate if it needs to when the engine is running...once the car is started it will charge if it needs to. This won't make any affect on the battery with the engine on. |
so they changed the design from the MY10 to the MY11 which what goal in mind?
Sorry Rambles but I think you're just trying to wind everyone up. We are trying to help you and can only tell you what we know or have been told. I personally don't have the need to use the FBH when it's been over 15 degrees for a few weeks now. If you have issues then I think it's best to contact your dealer to let them know how you feel. |
actually I think you're trying to wind me up.
I find that my front and rear climatic seats work perfectly well actually and as my FFRR is garaged I havent needed to use the FBH and am not able to with the car being inside because of fumes. I know the FBH works because of what I've described before. Have you had a dead battery Rambles? |
ah, well there you go. Mine is not garaged.
No but that's why I had my garages specifically designed to take FFRRs...
| Tomw2000 Member Since: 22 Jan 2011 Location: Hertfordshire Posts: 202
Epic fail. Unless you have beautiful vintage merc and bikes. But even then... |
+1 we did this too |
