Home > Maintenance & Mods (L322) > Rear back plates
Ben84
England 2005 Range Rover Vogue Td6 Tonga Green
Rear back plates
Hi, I need to replace the rear brake back
plates on my 2005 td6.
Does anyone have any recommendations
On the best place to purchase them and
the cost??
Thanks
Post #620855 21st Jan 2022 9:35pm
Ben84
Anybody??
Post #621144 23rd Jan 2022 9:04pm
try a search or look in the wiki... ... - .- -.
Post #621146 23rd Jan 2022 9:26pm
stuart_2006
Can't help directly, but there are various threads like this one [https://www.rangerovers.net/threads/l322-rear-brake-mud-shield-guard-replacement-how-to.268162/] on how to split and rejoin the back plate so you can fit it without taking the hub apart.
Post #621147 23rd Jan 2022 9:31pm
There’s genuine ones on eBay for £155 for the pair but you can probably get pattern ones cheaper.
Post #621148 23rd Jan 2022 9:32pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
What makes you believe they need replacing mate? If it's for the hand brake there's an alternative that's a simple but very effective fix
Post #621152 23rd Jan 2022 10:04pm
Ben84
The plates are badly corroded. The brake shoe retaining pins are all but ready to pull through.
Post #621159 23rd Jan 2022 10:37pm
Get some small hole penny washers, these are also good for the bolt holes.
Post #621164 23rd Jan 2022 11:06pm
Ben84
Already used washers as a temporary repair
Post #621170 24th Jan 2022 12:14am
It is much easier to repair what you have rather than replacing! Shocked
Stripping the hub off an old 322 is no fun trust me... Whistle
Post #621173 24th Jan 2022 12:39am
Bean19844
These little puppies here are your friends mate. Give you time too get the car ready to go in and have the rear hubs changed and the plates changed all in one go mate.
Post #621177 24th Jan 2022 2:23am
Ben84
Do they use the same backplate for
All the models of L322
Post #621454 26th Jan 2022 2:31pm
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I did this job to my car recently:
https://www.fullfatrr.com/forum/topic61174.html
I bought new back plates from Duckworths (Robin Hall) £120 total for x2 plates. I used some stainless steel brackets I had and pop riveted them to the back plates.
It was a bit of a pain to take the old ones off but cut them with a Dremel and used an angle grinder on the new ones with a slim metal cutting blade. Once the old ones were off it was a breeze getting the new ones on.
Make sure you have a spring removal tool as the drum brake upper springs are were a b*tch to remove. I bought one off Amazon and when I did the nearside it was so much quicker.
Post #621456 26th Jan 2022 3:00pm
2002 - 2012 are all the same. Thumbs Up
Post #621457 26th Jan 2022 3:26pm
Ben84
Thankyou everyone for your help.
Much appreciated.
Post #621513 26th Jan 2022 11:35pm
