Home > Technical (L322) > Adaptive Cruise and DSC
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
I use cruise control very rarely, but had it set today on the motorway and noticed the DSC light was on continuously. Adaptive cruise was working perfectly, and DSC light went off when I cancelled cruise control. Is this normal? No reference to it in the manual, and could find nothing searching here. Fault check with IID on return home and nothing untoward showing up. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #621126 23rd Jan 2022 7:23pm
mjdronfield
There is a light on the dashboard to show the cruise is on…. Sure it’s not that? Simple things first and all that….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #621130 23rd Jan 2022 7:30pm
RR2B
Err yes, the green cruise light was on as well. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #621136 23rd Jan 2022 8:05pm
GraemeS
Australia
DSC or ACC in follow mode?
Post #621140 23rd Jan 2022 8:48pm
RR2B
Both lights were on continuously whether clear road or following. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #621145 23rd Jan 2022 9:04pm
GraemeS
Australia
It's certainly not normal, indeed if DSC was switched off prior to setting CC/ACC then DSC gets switched back on. I would try switching DSC off then selecting ACC to see what happens but if still malfunctioning then I would disconnect the battery for a few seconds which will cause all ecus to cold start.
Post #621154 23rd Jan 2022 10:13pm
RR2B
Thanks GraemeS, I’ll give your suggestions a go. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #621200 24th Jan 2022 11:07am
RR2B
Ignore my post! A classic case of 'Should have gone to Specsavers' - it was the amber follow mode light, not DSC ! 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #621818 29th Jan 2022 7:13pm
mjdronfield
I meant to try mine the other day to check which lights come up where….. least you know now…
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #621819 29th Jan 2022 7:29pm
