![]() | Home > Maintenance & Mods (L322) > Which of these brands of brake pads to buy? |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Got Brembo marked discs and pads (front and rear) from AF a few years ago. Still performing well. Previous cars:
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
I have tried them all over the years and really the only ones to buy are genuine pads and discs they perform the best and dont squeal squeak or grind |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
I use Borg & Beck with no issues. Used them on my RRC, D1, P38A, and the L322. Ron B. VK2OTC
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
It depends a bit on which one in the range of the brand as well. But out of that lot I would choose Ferrodo as my first choice. I've got them on my S/C actually. Very good, silent, brake well, and don't provide much dust. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3326 ![]() ![]() ![]() |
Are you keeping the disks and just replacing the pads? 2012 TDV8 Vogue (L322) |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Well, initially I thought just new pads (I have had a very expensive month), but should I do both?
Always do both. 2012 TDV8 Vogue (L322) |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 781 ![]() ![]() |
The only after market disks/pads that I've ever been impressed with have been EBC, not cheap but work well and last well |
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 122 ![]() ![]() |
Not in my world. Pads when needed and discs when needed. Always both sides but pads wear quicker than discs |
Pad and disk wear rates vary depending on the setup and the pad compound. Putting new pads on worn disks means a long bedding in period in which uneven heating can occur as only parts of the pads are touching the disks at first. 2012 TDV8 Vogue (L322) |
@goldstar - you might have fired up a debate here |
If discs need changing I change pads as well. But if only pads need changing I only change pads. I’m normally running at like 2-3 sets of pads to a set of discs. |
Mine came with very worn disks and new pads. Really should get the disks changed soon before the pads wear through to the venting voids in the casting. I always used to do my own disk and pad changes and know how to do it on various systems but these days I'm happy to let a garage do it. Once it's up on the lift a good mechanic can change a whole set of disks and pads in way less time than I can do it with a jack and crouching down inside the wheel arch so the savings on DIY is just not worth it. 2012 TDV8 Vogue (L322) |
Bought EBC Greenstuff 4x4 brake pads all round after much research and forum recs.
