Home > Maintenance & Mods (L405) > Choice of oil for sdv8
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
Afternoon, any chance anyone has used petronas syntium 5000 fj 5w-30 oil in the sdv8 as it meets all the specs and is a good well known brand.When it gets the 12 month service they use the Shell Helix Ultra Professional AF-L Engine Oil - 5W-30 and i was thinking of using the petronas syntium 5000 fj 5w-30 for an inbetween 6 month oil service which it currently does not get .
Any thoughts or experience of using this oil would be appreciated. Thanks
Post #621240 24th Jan 2022 4:45pm
Landphil
If the Petronas oil is a Fully Synthetic Engine Oil and says it is ACEA C1 Low SAPS Ford WSS-M2C934 then you can safely use it. If it doesn’t you shouldn’t use it.
Post #621278 24th Jan 2022 10:12pm
knwatkins
As above. If it meets the spec, it'll be fine. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #621305 25th Jan 2022 9:06am
Baltic Blue
Opie oils include it in their options for the 4.4 tdV8, but are showing it out of stock.
Post #621308 25th Jan 2022 10:00am
154JON
Morning
Thanks for the replies, has anyone used it, i know there are a few very cheep oils that meet the spec but this one seems to be a very well known brand that meets the spec at a good price. Thanks
Post #621309 25th Jan 2022 10:07am
dingg1
If it meets the specifications required it doesn't matter what name is on the label, thats just preference or marketing...
Post #621310 25th Jan 2022 10:11am
DrRob
I use Morris of Shrewsbury's version that meets the spec Thumbs Up
C1 5W-30 and spec WSS-M2C934 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #621322 25th Jan 2022 10:58am
Landphil
Just ordered 20ltrs from Smith and Allan on Kev Watkins recommendation.
Post #621358 25th Jan 2022 4:42pm
knwatkins
I've been using S&A for a few years. Good stuff, meets the spec and great value Thumbs Up Kev
Post #621361 25th Jan 2022 5:00pm
