Home > Technical (L322) > Urgent adviee needed , please help !
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Right guys , doin my turbo on td6 right now but theres hardly any play BUT the crank case breather is rock solid in oil , how can i test to see if its at faumt before i go any further with the strip down
Post #621747 29th Jan 2022 11:12am
JayGee
You mean the oil return pipe from turbo to sump? This should definitely be clear otherwise the oil can't circulate through the shaft bearings. 2012 TDV8 Vogue (L322)
Post #621750 29th Jan 2022 11:25am
bembo449
No pal i mean the crank case breather on top of the left hand side of the engine , will be checking the return next
Post #621754 29th Jan 2022 11:40am
mjdronfield
I imagine you could just take the filter bit out, that’s solid, and see how it runs.
When you upgrade to the later vortex one, which will never block and never need changing, you can just get the filter bit or change the whole bit, so the original one is just like a small foam type filter.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #621756 29th Jan 2022 11:43am
bembo449
Think im guna have too pal
Post #621757 29th Jan 2022 11:44am
mjdronfield
Pretty sure that will sort it mate. Get a later vortex one ordered for a BMW…. Not Land Rover or you will get the crappy design you already have.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #621758 29th Jan 2022 11:50am
mjdronfield
Like this, most folk change the whole unit, but you can just get the vortex bit and cut some plastic tabs and fit to yours.
Sounds like yours has had it, so I’d just swap the entire unit if it was me…..
https://www.ebay.co.uk/itm/372611832868
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #621761 29th Jan 2022 12:02pm
bembo449
Ordered a new one but cant get it till nay unfortunately
Post #621764 29th Jan 2022 12:27pm
bembo449
Ive run the engine till warm and there is only blueish smoke when i press the throttle and rev to 2/3k at idle theres none at all , im convinced the turbo is ok
Post #621771 29th Jan 2022 12:58pm
mjdronfield
Probably chucking the crud out. Filter tends to always gets missed when servicing at a garage, and causes all sorts of issues. That’s why BMW changed the design, but that was after they had sold Land Rover.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #621773 29th Jan 2022 1:04pm
bembo449
Will give it a good run tomorrow and fingers crossed, the problem will be srted
Post #621774 29th Jan 2022 1:09pm
mjdronfield
I fitted a K&N air filter element too, which I get the pros and cons of these things, but that meant the engine cover didn’t have to come off at all when servicing…. Unless you wanted to check the air filter…. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #621778 29th Jan 2022 1:32pm
bembo449
Air filter is ok 👍
Post #621779 29th Jan 2022 1:37pm
JayGee
A blocked crank breather can force oil out of the turbo seals (and cause smoke) as it pressurises the return to the sump. Common issue on old diesel cars where sooty blowby gases mixed with oil and water vapour create a nice black tar. 2012 TDV8 Vogue (L322)
Post #621780 29th Jan 2022 1:44pm
bembo449
Ok thats helpful info , as above , instict / experience tells me the turbo is ok and hopefully with the breather renewed the residue in the exhaust will burn off , if not i have a new charger i can fit anyway
Post #621781 29th Jan 2022 1:48pm
