Home > Technical (L322) > Urgent adviee needed , please help !
JayGee
Turbo should be OK if the endfloat and radial play are within specs. A pressurised turbo drain won't restrict oil flow through the turbo as this is at much higher pressure - good luck. 2012 TDV8 Vogue (L322)
Post #621783 29th Jan 2022 1:53pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Id reckon theres less then .5 of a mil playin the bearing , ive seen alot lot worse in my time and the car has run just fine
Post #621784 29th Jan 2022 1:55pm
