![]() | Home > Maintenance & Mods (L322) > Wheel ramp recommendations |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Good morning ladies and gentlemen, boys and girls…
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 781 ![]() ![]() |
Move? |
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 122 ![]() ![]() |
Hydraulic ramps. Not sure if you can get a set that you can raise to different heights? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
This set up works well for me on my sloping drive, but you would have to place the lower side ramp on blocks to overcome side to side slope.
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 207 ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35829 ![]() ![]() |
there are normally a pair of chocks in the spare wheel compartment.. ... - .- -.
![]() It’s on the list! Unfortunately location, demand, poor wife life choices hindering that plan! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
I did see a set a while back that had that. You drove onto the top part of the same and jack it up. It was an expensive option so moved on… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
I had a set in which each ramp had a bottle jack to raise the top plate of the ramp. I got them off Ebay. IIRC they were about £100 the pair. John
That was far cheaper than what I see! I thing I’ll take a nosey at the bay… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
That’s what I was thinking! Not a bad price too! ![]() Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 ![]() ![]() |
My drive slopes two ways, so I decided which part of the drive I wanted the car to be on to work on it and made four drive on ramps out of timber, each a different height so when on them the car is level.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I get scared just seeing some of this. To me there is a reason why the floor should be level, and you shouldn’t use a ramp to make it level and lift.
From a safety point of view it’s not an issue, the car is totally stable. It’s only about an extra 5 inches off the ground and I check with the car in N, EPB off that the car doesn’t move. Then, with the car in P and EPB on and the wheels chocked ( the chock you can see is held in with a long screw) I raise the suspension, stop the engine and put axle stands under the chassis. Finally I always open a door. Nothing moves.
