![]() | Home > In Car Electronics (L322) > blinking power button but screen blank |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
Just to add to this , what should be behind the NSR boot panel ? If something is missing that will explain why its not working , like a DVD player? I had vogue previously so unfamiliar with the lower spec models unfortunately |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7930 ![]() ![]() ![]() |
Really need pictures……
cant provide any right now pal , sorry but if you imagine the flashing power button with a blank black screen , thats what i have , ive read / seen youtube vids where the LR logo is on screen with power button flashing and a poss cure for that but cant find anything where the screen is blank , the boot comp looks dry but as i said earlier , is there something missing from that area ? the BT module is there and the vertical silver box but nothing else and i cant find info on what the SE infotainment system should contain |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3267 ![]() ![]() ![]() |
Usually if something breaks the fibre optic ring you’ll get an orange flashing light and the LR logo on the screen.
Its a td6 pal ignition key is near gearstick too |
[img]https://linksharing.samsungcloud.com/tA90dKzwjr1f
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 ![]() ![]() ![]() |
Take a look in the left hand panel in the boot, there is a "stack" that includes the Bluetooth module (on top) and then the amp, NAV CD etc. There is a fibre optic cable that loops to each one of these. If one of these fails then its breaks the circuit. You will probaby find if you pull the plugs some blue residue where water has run down the cables from a leaky window seal. If you can work out which one it is you can get use a biro to make a temporary bridge on the fibre optic cable and this will enable you to test if this is the issue.
Ok pal , can you not see the link i posted? I think theres something missing from the boot compartment!? I reckon if i know what i will understand why i have my issue . . . Then jjust go android 😄 |
Hi Bembo.
Ok pal , will look at that 👍 |
Right, ive looked at all the fuses ( i think ?) Tried looping the fibre optics , still nothing , anything else to look ? |
Shinner23 Member Since: 18 May 2020 Location: Virginia Posts: 6 ![]() ![]() ![]() |
Did you ever find out what it was? |
Bit of info here….
