Home > Maintenance & Mods (L405) > Is Atlas Silver the correct colour
Van Diesel
United Kingdom 2014 Range Rover Vogue SE SDV8 Mariana Black
For the side trim and vents on the L405? Noticed a small chip and want to get a touch up 2021 Defender 110 D300
2014 FF 4.4 SDV8
1986 3.9 V8 90 Pick Up
2011 FF 4.4 TDV8 (Gone)
2008 FF 3.6 TDV8 (Gone)
Post #621879 30th Jan 2022 5:39pm
pld118
Atlas silver is one of the colours for them.
If you email Duckworth LR or a LR parts department with your reg. / VIN they can give you the build sheet and/ or they can tell what colour the trims are to be sure.
Unless they’ve been added since it was new?
Post #621884 30th Jan 2022 7:19pm
Van Diesel
Thanks for that. Pretty certain it's all original so will give that a try. 2021 Defender 110 D300
2014 FF 4.4 SDV8
Post #621886 30th Jan 2022 7:45pm
Should say on a sticker if you pull the trim part off sir... Thumbs Up
Post #621919 31st Jan 2022 12:53am
pld118
I’ve got a pair of genuine LR Atlas silver vents that I removed in favour of a pair of genuine Santorini black ones…. Given what Craig says, if you get stuck I’ll go up the garage loft and see if the codes are still visible Thumbs Up
Post #622029 31st Jan 2022 9:01pm
My point was for the OP to know for sure what’s on his own car, he could pull off a panel and see Ryan… That way there can’t be any disparities with pictures of other members panels if that makes sense???
Post #622030 31st Jan 2022 9:09pm
pld118
It does/ did indeed Craig… From memory I’m not actually sure the stickers on ours remained legible although I know for sure ours are Atlas silver (I’d dig them out to try and help though/ but they’re not for sale 😂
OP might not want to pull his off and if he’s sure the vents are then original the build sheet should help… that said, does LR even do an Atlas silver touch up stick or are you better just going to a Bodyshop/ paint shop to get them to view and colour match it? 👍🏻
Post #622039 31st Jan 2022 10:33pm
I think a wheel specialist might be the best option for oddball colours... Thumbs Up
Post #622047 1st Feb 2022 12:40am
