![]() | Home > Wheels & Tyres > ALWAYS check the inside of your tyres!! |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1473 ![]() ![]() |
Rather shaken about this, but think it worth sharing.
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 302 ![]() ![]() ![]() |
Very lucky there, and a very timely reminder - thanks. I can imagine how you felt. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35757 ![]() ![]() |
you was lucky Rob..
Yes, I feel very lucky Stan |
you wheely have a 'wheel' problem Rob.. |
Good one Stan...... |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
Interestingly a couple of years ago I had similar on both nearside tyres and only found it when swapping from winter to summers glad you caught it before a disaster |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226 ![]() ![]() ![]() |
Thanks for posting, good reminder to be more vigilant, glad you/they spotted it and all is well. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1844 ![]() ![]() |
That looks like an alignment issue... |
Guessing you meant 3000 not 33000 ![]() |
I run winters and summers so change wheels every 6 months or so and always have 4 wheel alignment done so every 6 months about 10k miles and there are always adjustments so well worth having it done at least annually I guess |
Yes, it's a Pirelli Scorpion. Damage is very much mechanical and not an alignment or uneven wear issue. We have some shocking potholes around here ![]() 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
What’s the DOT age on the tyre? Looks like failure of the compound rather than damage. 2012 TDV8 Vogue (L322) |
The tread pattern has worn away, and the tyre is cut down the middle of this If the wear is localised to that one part of the tyre, then I'd agree its a mechanical failure of the tyre construction However, if that wear is evident around the entire circumference of the tyre, then something has worn it away... |
