![]() | Home > Technical (L322) > Suspension not lowering to access height |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
Might not be this, but I’d remove the exhaust filter from the air suspension compressor and try again.
https://www.fullfatrr.com/forum/topic23038...ust+filter
Giffer2018 Member Since: 25 May 2020 Location: West Yorkshire Posts: 63 ![]() ![]() ![]() |
Thanks for that mj, will try that in next few days. -----------------------
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
You can clean the exhaust filter with some hot water. Don’t remove it permanently. It’s got a purpose. Christian.
I tried soaking mine in Petrol but it was still blocked. You could buy new ones for around £32 but not sure if you can now.
I just used hot water and an airline. Seemed to come up sparkling really easy Christian.
Thanks for that Caesium. -----------------------
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
+1 for the hole drilling did it about 6 years ago and still ok in fact after drilling it watched as it lowered and raised the car the amount of white powder that came out was interesting |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 112 ![]() ![]() ![]() |
Another +1 for hole in filter , sorted mine out 5 years ago and still working fine . |
Hi chaps,
Excellent. Saved about £700 there 🤣.
william Jones Member Since: 22 Feb 2023 Location: South Wales Posts: 5 ![]() ![]() ![]() |
I have just done this today, and it rectified my slow to access mode problem, great fix, cheers guys ! |
Nice one. I appreciate it’s not the fix Land Rover would do, but no issues with mine…. However many years later….
Had same issue when I got mine nearly 7 years ago , hole in filter sorted it (6/1//2 years ago) not missed a beat since and it get's lowered nearly every time it's parked (wife has little legs and easier for dogs to jump in boot ). |
