Home > Maintenance & Mods (L405) > Secondary battery ripnoff
Blackbird
United Kingdom 2015 Range Rover Autobiography TDV6 Santorini Black
Hi guys,
Just been exposed to one of the biggest rip offs at a stealer in York that you may be interested in. My car is in for a major service including timing belt. I ask them to check out the start stop function which has stopped working. They wanted £120 to run diagnostics which I reluctantly agreed to. They then called me to say that the problem is the secondary battery and they want a further £426 to replace it. So total cost for the battery replacement £546. I have declined this and have ordered a replacement Exide battery from Amazon for £39.00 and will changed it myself.
Post #622216 2nd Feb 2022 1:33pm
you wont be going there again then... ... - .- -.
Post #622223 2nd Feb 2022 2:30pm
And invest in an IIDtool Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #622224 2nd Feb 2022 2:38pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
My stop start had not worked for about 2 years and when it went in for its 6 year service at a good local indy I asked for a quote for replacing both batteries. They gave me the price and told me that was list on both but they did not charge for fitting, they also said they would only fit OEM as they had had problems when trying less expensive ones.
I now have to start the car and instantly turn the stop start off as it now works perfectly. letters not necessarily in the right order
Post #622226 2nd Feb 2022 3:17pm
Kot
I hate the stop start and religiously Rolling with laughter turn it off every trip.
Then I hate myself when I stop at a junction and the car stops --yes I forgot again Rolling with laughter Rolling with laughter Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #622227 2nd Feb 2022 3:41pm
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
Me too, it's complete habit now. FFRR SDV8 Autobiography
Post #622229 2nd Feb 2022 3:47pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Imagine the P400e (PHEV) then: the engine usually starts at stops to recharge the HV battery Rolling with laughter
Post #622237 2nd Feb 2022 5:39pm
hate the stop/start...disconnected mine as soon as i got my FF.. ... - .- -.
Post #622241 2nd Feb 2022 6:30pm
Blackbird
Thanks for comments. Although stop start is not essential I just think if it’s there it should be working properly. Just fed up with how greedy these damn dealers are. As Stan says I won’t be going back.
Post #622264 2nd Feb 2022 9:24pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Won' be long beore some tree hugging clowns are demanding a working stop start be part of the MOT....
Post #622417 4th Feb 2022 10:44am
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
What is it about stop/start that people hate?
Post #622426 4th Feb 2022 11:45am
Kot
The extra drain on the battery after each start (we all know a FF doesn't need that monkey on its back), the extra strain on the starter motor, the extra wear and tear on the engine, the thought knowing that in a traffic light stop, its going to start before the lights change anyway. Pointless arghhhhhhh
Post #622431 4th Feb 2022 12:16pm
Phil.
Also, when the engine is hot, stopping can cook the alternator and other parts. It’s needed for the EU tests but serves little positive purpose in normal use. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #622442 4th Feb 2022 2:34pm
Yep turn mine off. It always sounds slightly alkward when it restarts….. There is nothing that can't be fixed with a hammer😜😜
Post #622556 5th Feb 2022 3:06pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
I'm guessing that stop/start is fitted to most cars now because:
a) you can and it's not too expensive (the customer picks up the bill anyway).
b) in the WLTP test I have no doubt that part of it requires the car to be effectively stationary, so clearly if the engine isn't running it isn't using any fuel. This will have a stupidy disproportionate effect on fuel consumptoin because the test only runs to Tesco and back. Thus all new cars will easily do 500 mpg.
In real life it will make the square root of Censored all difference to fuel consumption, It's a stupid gimmick with all of the pitfalls previously mentioned, its how manufacturers 'legally' fiddle the sytem to have the 'best' performing vehicles, they all do it and it's cynical in the extreme. About what I'd expect from most big business. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #622675 6th Feb 2022 9:48am
