![]() | Home > Technical (L322) > Code P0088-00 |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Random faults?
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 761 ![]() ![]() ![]() |
Unlucky Bishbosh
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
High Fuel Pressure. Either fuel line, pump or sensor fault. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1847 ![]() ![]() |
Usually sensor. Done a few over the years |
@mikey |
Thanks guys appreciate that, could the fuel filter also be part of the issue? 2014 vogue se |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3310 ![]() ![]() ![]() |
A friend of mine had something similar happen when his alternator was in the early stages of failing. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Is it a whole rail or just a switch Mike? 2014 vogue se |
Pretty sure you can't buy the sensor alone, only comes as part of the rail
Thank you 2014 vogue se |
Fault rectified! Was indeed the fuel rail sensor!
