Home > Maintenance & Mods (L405) > Loose door panel
supershuttle
Loose door panel
I’ve had a search and come up with nothing. The door card on the passengers side keeps coming loose and flapping about at the bottom. I’ve replaced all the poppers but it still does it (obvs banging them all home fixes it but it doesn’t last). I’m thinking of resorting to Velcro pads or even double sided tape. I’ve suggested to SWMBO that instead of slamming the door she might consider using the soft close facility - it would be easier teaching a crocodile to fly. Any suggestions? Geoff
Post #622831 7th Feb 2022 10:28am
actual they do exist Geoff.. Mr. Green
first of all i'd look to see why these clips arnt staying in the holes..are they the correct ones?
if its a case of they are the right ones and wife is very strong then some gorilla double sided tape will do the job. ... - .- -.
Post #622841 7th Feb 2022 12:41pm
supershuttle
I realised after I posted that the flying crocodile was more interesting than my door. Its not a big job to remove the door trim but its not an "outside" job either - cold and damp here. However, I will have everything to hand for all the options when I do take it off, it's not urgent but it bugs me. Geoff
Post #622842 7th Feb 2022 1:08pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
I would try just putting a loose clip in each hole and making sure there is nothing obstructing them going fully home. Might be the plastic liner? 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #622843 7th Feb 2022 1:12pm
