Home > Maintenance & Mods (L322) > First scan with Gap IID tool
Jimmies
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Bournville
My car is working fine with no errors showing on in car screen......anything in the below that I need to do anything about?
BCM-Body Control
B112C-96 (2F) Interior motion sensor - Component failure - internal failure
C111B-15 (2F) Left stoplamp - General electrical failure - circuit short to battery or open
B1247-15 (2F) Rear left turn signal - General electrical failure - circuit short to battery or open
PCM-Engine TDV8 4.4L
P040D-00 (2F) Exhaust gas recirculation temperature sensor A - circuit high
Thanks in advance
Post #622992 8th Feb 2022 7:24pm
DrRob
P040D is a well known exhaust temperature sensor on passenger side. Usually causes no issues. Full write up on here on how to replace but if car is not showing any warnings then no need to worry.
I'd clear them all and then recheck in a weeks time. The P040D will always come back. I had my sensor replaced by a specialist when it was in having other stuff done. I thought I might aswell get it done. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #622993 8th Feb 2022 7:49pm
Jimmies
Hello DrRob...I did do a full clear and these where the ones that stayed....my left rear light cluster seems to be working fine so maybe there is just a gremlin in the wiring
Post #622998 8th Feb 2022 8:10pm
