![]() | Home > Maintenance & Mods (L322) > Rear Caliper Spring Clips Binding |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 714 ![]() ![]() ![]() |
The pads should slide with relatively low finger pressure.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491 ![]() ![]() ![]() |
Hi, once the calliper is off you can flick the spring clips out to clean the casting then re-fit, ideally new clips but if no access to new the old ones can be re-used if still in tact.
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 282 ![]() ![]() ![]() |
The TRW pads that I took out had the same problem as the new Jurid pads I was trying to put in. However, one side was definitely easier than the other regardless of which pad I put in that position so I cleaned the corrosion off the spring clip and the bracket and eventually got it to slide in a bit easier. I will make sure I get new spring clips next time as well. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1362 ![]() ![]() ![]() |
It can sometimes be just the thickness of the paint on the new pads making them to tight. I use a grinder or a good sharp file to remove any surplus material to make them slide.
