Home > Maintenance & Mods (L405) > L405 Turbo Crossover Valve
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
Hi Looking for some advice about the crossover valve that goes between the two turbos I have been advised that I need to replace mine. (I have had a restricted performance warning and boost code warning) Has anyone any ideas about this where it is how much would it cost and can i do it myself
Thanks
Post #623064 9th Feb 2022 5:39pm
Baltic Blue
http://www.fullfatrr.com/gallery/albums/us..._TOPIx.pdf
I presume you are referring to the turbo CSOV.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #623066 9th Feb 2022 6:02pm
Baltic Blue
Mine is a 4.4 tdV8 L322, but the L405 is very similar.
Mine was the old design and replaced under warranty with the later L405 type , when it stuck and caused the car to go into restricted performance every time I got the revs up to 2,500 rpm.
It’s a fairly easy job if you get the front of the car raised and work from underneath., although it can be seen from above if you look down to the right behind the radiator.
Post #623069 9th Feb 2022 6:12pm
Pat
Hi thanks for the replies yes its the CSOV I am talking about
Post #623082 9th Feb 2022 7:53pm
Baltic Blue
I have just noticed that your L405 is 2013, so it is very possible that it will have the earlier nut type.
If so, you can get to the nut from the top by simply removing the throttle body hose .
If you slacken it off and give it a good squirt of WD 40, it may well free it enough to give a repair until you can replace it.
Mike.
It is described in detail in the 2011 W.M. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #623099 9th Feb 2022 9:26pm
