Home > Maintenance & Mods (L405) > Powered Tailgate Not Closing - Now Resolved
JCW
Picked up the replacement to my L322 5.0 SC today, an MY15 L405 SDV8 Autobiography, one immediate issue I have is the tailgate doesn’t power close when pressing either the button on the upper tailgate or key fob. Opening works perfectly with both parts fully opening, when trying to close I can hear a faint clicking behind the r/h trim panel (relay?) and three beeps.
I knew it had this issue when buying it (private sale) but am hoping it’s an easy fix - any ideas where I should start looking?
Thanks Thumbs Up
Post #623198 10th Feb 2022 8:33pm
will it close using the button by your right knee? ... - .- -.
Post #623215 10th Feb 2022 10:19pm
JCW
Hmm, not tried that Stan - I’ll give it a try Thumbs Up
Post #623216 10th Feb 2022 10:21pm
could be the sensor strips either side of upper tailgate need replacing..
https://www.fullfatrr.com/forum/topic59143...te+closing ... - .- -.
Post #623217 10th Feb 2022 10:22pm
JCW
Button on the dash does the same thing as the key fob and upper tailgate button - tailgate opens but doesn’t close - just three beeps
Listening again this morning, as well as the three beeps there’s also a click from the upper tailgate latch mechanism when pressing the close button (all three options) so I wonder if there’s possibly an issue with that, although when closing the tailgate manually, it does latch & lock ok.
DrF I note you had a similar issue in the thread Stan linked above - don’t suppose you have any more detail on the sensors that were replaced?
Thanks all.
Post #623257 11th Feb 2022 10:09am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
PM Sent
Post #623263 11th Feb 2022 10:54am
JCW
PM received, all clear & understood - really appreciate the help Thumbs Up
Post #623266 11th Feb 2022 10:59am
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Are we allowed to know the solution please?
I have had this a few times now, then it cures itself for ages, then starts again and so on.
Ta Thumbs Up
Post #623268 11th Feb 2022 11:09am
JCW
The anti-trap sensors, integrated into the black trim on each side of the upper tailgate, are part no’s LR034417 and LR034419.
I’ll buy some & report back…
Post #623270 11th Feb 2022 11:25am
JCW
Had a quick look, they just pull out from the side of the tailgate when open, only secured with push fit clips -
Post #623273 11th Feb 2022 11:43am
RRV8SC
Post #623275 11th Feb 2022 11:47am
MonkeyMan
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
This was a 405 rather than a 322, but the solution here fixed mine: https://www.fullfatrr.com/forum/topic60938.html
Post #623286 11th Feb 2022 1:19pm
JCW
Thanks Monkeyman, I tried that but no luck, although it’s my upper tailgate as well as lower that fail to close, I’m hoping the new upper tailgate sensors resolve it Rolling Eyes
Post #623343 11th Feb 2022 9:16pm
those part numbers come back as tailgate mouldings ..i assume the sensor is integrated into them? ... - .- -.
Post #623358 11th Feb 2022 10:21pm
JCW
Yep that’s right Stan, you can see the wire exiting the tailgate in my first photo, this runs down and into to a rubber square at the bottom of the trim that looks like some sort of bump stop. Not clear to me how it senses an object whilst closing but I’ve ordered the parts today and hopefully will sort the issue Rolling Eyes
Post #623359 11th Feb 2022 10:27pm
