Home > Maintenance & Mods (L322) > Bonnet replacement
Rom
Netherlands 2012 Range Rover Vogue TDV8 Santorini Black
Bonnet replacement
Hi all,
Would like to replace the bonnet with one in a better condition (zero corrosion), but not clear what side of the hinge it is best to remove also taking the setting and ease of adjustments with the replacement in consideration. Both options either from the bonnet or the chassis side it looks like I cannot reach the back screw. The old bonnet is from a 2010 3.6 TDV8 and the new one is from a 2012 4.4 TDV8
Maybe I haven't right but couldn't find in the workshop manual or wiki.
Post #623391 12th Feb 2022 10:22am
darrenm
Did you even sort out removing bonnet as I need to replace mine
Post #713997 13th Mar 2025 8:10pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Pop the struts off and open wide, slide the service locking tabs into place ( thin metal things on the hinge) and the bolts are accessible. Need an assistant to lift it away. Its very light but big and awkward.
Edit, leave the hinges affixed to the bonnet, remove the inner wing bolts.
Chris
Post #714002 13th Mar 2025 10:54pm
darrenm
Well that’s todays job ready to start
Post #714112 15th Mar 2025 12:48pm
