![]() | Home > Maintenance & Mods (L405) > Minimum Disc Thickness? |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1422 ![]() ![]() |
You are allowed 2mm wear, so if yours were 34mm new, you are allowed 32mm.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1481 ![]() ![]() |
Thanks |
I dont know, they will test the brakes if they pass, they pass but if your pad thickness alarm is on thats another matter |
But the dealers are keen to check it for you |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
Minimum disc thickness for the front is 31mm
For MY18 JLR spec
Yes, it's marked on the outside edge |
Thanks all.
