![]() | Home > General > Connecting iPod to range |
Ludzy Member Since: 27 Oct 2010 Location: Leicester Posts: 191 ![]() ![]() ![]() |
Having problems connecting my iPod to the car. It's a old iPod so I thought of just using the aux 3.5mm cable but the volume seems really low. Also tried with some phono's but couldnt get any sound at all. Not a problem with the iPod as volume is fine when plugged into other things. Am I doing something wrong? Don't want an actual kit. Using a cable is fine or me but can't work out why the volume is either low or no sound a all using phono's.
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 404 ![]() ![]() ![]() |
Ludzy,
So basically to get any good normal volume it's best to get a proper ipod kit. I did have a itrip but when I cant seem to find it DOH!!!
I use one of these cables which also allows me to charge the IPOD and it has the video capability as well meaning the IPOD can be used as a video source. A 160GB IPOD holds a lot more DVD films than the 6 DVD changer in the boot.
Dogman Member Since: 10 Dec 2010 Location: UK Posts: 174 ![]() ![]() ![]() |
Using the stereo jack lead on my 2007/57 I get amplified volume via the speakers (no RSE on mine)?
ZZT Member Since: 02 May 2011 Location: NJ Posts: 3 ![]() ![]() |
All mp3 players are designed to drive headphones. Headphones simply do not need the same signal level as the AUX input. If you are going to use a headphone output, you'll need some type of in-line amplifier. Google "portable headphone amp" or "Sound Shocker Pro" and you'll find lots of info. Almost all need some sort of power (battery or car plug-in) except Sound Shocker. |
This is only if you're not running through the car's amplification as you only need 'line level' (approx -10bd) in general to run via an amp and as the ipod/iphone stereo jack output is amplified it may produce more than this (without checking I cannot confirm) so you would not need the amp.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
You lot are lucky - I haven't got an aux input on mine |
Well my ipod is only the 3rd generation. First with the colour display but only 20gb. In all my other cars I've just filled it up with songs and leave it in the car. I think I'm gonna have to have a good look for my old itrip. That worked perfectly through the radio.
It's not an impossible mod... You just need to replace the BM54 unit with a newer one. ![]() ![]() |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
I have experienced low volumes with both RR and BMW aux connections - Cure ? Purchase an ipod specific in line connector
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
Just tried it......unfortunately no difference than using a 3.5mm jack ![]() Gone: 1 x L405 and 2 x L322's |
Strange. my RR is a 2007 model for reference and as I day I am more than happy with the loudness and quality for what it is (ipod/mp3) and I am quite fussy over music.
