Home > Technical (L322) > Budgie in my engine
JayGee
Budgie in my engine
Had the belts and tensioners + waterpump replaced last year but had an cyclical chirping on cold starts for the last few weeks from the lower front OS area. Suspected the alternator but now noticed the 'chirp' does not rise with revs so think it maybe the viscous fan coupling? 2012 TDV8 Vogue (L322)
Post #623759 15th Feb 2022 12:21pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
If chirping not affected by rpm, are you sure it is accessory belt / pulleys ?
How’s your blower motor …….
Post #623799 15th Feb 2022 5:15pm
JayGee
It's coming from the front of the engine low down on the left and if I spray WD40 down there it stops. 2012 TDV8 Vogue (L322)
Post #623801 15th Feb 2022 5:20pm
DrRob
Did you change the one top left as you look at the engine?
 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #623810 15th Feb 2022 6:22pm
DrRob
Mine was Censored and was the main culprit for budgie noises...or more like a budgie being killed Shocked Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #623811 15th Feb 2022 6:23pm
JayGee
No idea as the garage did it and assumed they changed the lot. 2012 TDV8 Vogue (L322)
Post #623816 15th Feb 2022 6:54pm
JayGee
03? 2012 TDV8 Vogue (L322)
Post #623818 15th Feb 2022 7:00pm
DrRob
Should be on your invoice to cross check part number Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #623824 15th Feb 2022 8:12pm
JayGee
13deg this morning and no noise on startup. 2012 TDV8 Vogue (L322)
Post #623920 16th Feb 2022 6:07pm
JayGee
Think it's oil on the belt dripped down from spilling it while topping up without a funnel. Not easy to clean as it's so inaccessible. I can see a possible method with a stick and a pad soaked in brake cleaner to hold under the ribbed part as it's moving but it's not ideal and there's a ( big) risk it would slip and.... 2012 TDV8 Vogue (L322)
Post #625221 3rd Mar 2022 11:39am
JayGee
Gave it a good squirt in detergent from a hand sprayer while it was running just now. Definitely a belt contamination issue as the chirp is exactly in time with a white marking on the belt and it goes quiet when the detergent was first squirted on ribbed side. May need a few applications to cure it. 2012 TDV8 Vogue (L322)
Post #625227 3rd Mar 2022 12:47pm
