Home > Technical (L322) > 3.6 TDV8 vacuum diagram
beeza
England 2010 Range Rover Supercharged 5.0 SC V8 Java Black
The car has recently come back from the shop after a transmission repair and an exhaust manifold gasket replacement. Unfortunately the engine had to come out to get the manifold off.
The car is running ok, but every now and then it goes into limp mode with the codes P065E and P2071. Both are related to the intake manifold tuning valve. It resets ok after a switch off and on, but comes on again at random moments and goes into limp mode.
Looking at the engine I have a spaghetti matrix of various vacuum lines, most of which are broken or ready to break. They are extremely brittle and the slightest disturbance breaks them. I would like to replace all the vacuum lines as I suspect this may be the cause of the this manifold tuning vale as I understand it is vacuum driven.
Please could someone furnish me with a vacuum tubing schematic?
Year 2008 Vogue TDV8
Many thanks.
Post #623846 15th Feb 2022 11:47pm
beeza
As an edit, my profile says I'm in Kent. Well that's where I'm from, I'm actually in the Dominican Republic where cars suffer from tropical climate faults such as brittle plastics and bad mechanics!
Post #623848 15th Feb 2022 11:49pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
On the back of the cam covers/inlet manifold, there are vacuum actuators that move flaps integral to the cover. Have a look to see it the hose has broken or come off, same both sides and a pig to get at. Some pictures for guidance in this thread.. https://www.fullfatrr.com/forum/post431827.html 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #623869 16th Feb 2022 8:54am
