![]() | Home > Technical (L405) > GAP IID and Oil Dilution 2017MY |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1431 ![]() ![]() |
Gap do not support my MY18 and MY above so I never bothered to buy one.
D.Sloan Member Since: 14 Feb 2020 Location: North Yorkshire Posts: 19 ![]() ![]() ![]() |
Thanks for your reply Kot.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35852 ![]() ![]() |
the GAP iidtool only supports up to year 2016 at the moment and even then on the 16my it has limited functions..... ... - .- -.
Thanks Stan, seems I will have to wait a while! |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 507 ![]() ![]() ![]() |
GAP have been saying they will add the newer RR for at least the last 2 years. I will believe it when I see it. SDV8 AB MY 2020
An extra oil change is the way to go ![]() flea bay at £120 well worth it there are good threads on here on how to use it. 2018 SE SDV8 4.4 Byron Blue |
Thanks very much for all the replies. I am going to do an extra oil change at the start of each season which fortunately is midway through my service interval so hopefully this will ensure there are no issues.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
The best way is definitely an extra oil change, but you can always check the miles to next service on the dash to tell you how far you have to go. It works on an algorithm in the ECU to determine oil dilution, once you reach 7% it will register 0 and call for an oil service. Just be careful as on most it may say 2000 miles to next service but you only get say 600 due to short journeys ETC. I also tow a twin axle van and always chuck an oil service in at the beginning of the season, I keep my own record so I never go more than about 7k miles without an oil change |
Thanks Dave, makes complete sense so oil change at the start of the season it will be. |
So the question is!!!! What big change happened after MY16, that has completely defeated the GAP team? 2018 SE SDV8 4.4 Byron Blue |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1482 ![]() ![]() |
I think Craig may have confirmed this on another thread, but my understanding is that for MY17 onwards there was a complete change in the Canbus system that connects all of the control modules which resulted in the IID tool (and others) being unable to talk to and re-configure the various control modules.
