Home > Maintenance & Mods (L405) > Rear lens replacement L405
Page 2 of 3 <123>
supershuttle
Cam-Tech-Craig wrote:
Yes, they are sonic welded together... I would simply break the old cover off bit by bit Careful NOT to touch any chrome inside as it'll be ruined by the oil in your skin... Then glue the replacement on using some form of PU Thumbs Up
Yep, I touched the reflector on my l322 foglight - the silvering then just wipes off. DO NOT TOUCH!!! Geoff
Post #621662 28th Jan 2022 1:55pm
Pendle
United Kingdom 2016 Range Rover SVAutobiography SDV8 Firenze Red
Hi, I totally agree having done the job it looks ok to a casual observer but I know that it is not quite right! Ebay here I come! L405 SV Autobiography 2016
XJS V12 Convertible 1990
Previous:
L322 Vogue SE 2011
Mazda MX5 1999
Saab 9-5 2.0 SE 2000
Discovery 3 door 300 Tdi 1995
Fiat X1/9 1983
Citroen BX 1.9 GTI Turbo 1987
Austin Princess Vanden Plas 1972
Several too embarrassing to publish and a bunch of Company cars incl RAV4 Honda Accord Coupe and a Bora.
Post #621724 29th Jan 2022 3:36am
number76
United Kingdom 2014 Range Rover Autobiography TDV6 Santorini Black
Pendle wrote:
Thanks Cam'
I am getting more nervous by the post!
But thanks to all for tips and advice
This is the lens type I plan to replace!
Hi, where did you find your replacement lens for this year and model light please?, i see that powerful have the 12-17 model lens, but not the newer type.... 2014 L405 3.0 V6 Autobiography Santorini Black 49k
Post #621753 29th Jan 2022 11:40am
Pendle
From powerful uk
Replacement Rear Light Lens for Range Rover L405 (2018+) - LEFT LH
SKU : RLG535-L
£63 L405 SV Autobiography 2016
Previous:
L322 Vogue SE 2011
Mazda MX5 1999
Fiat X1/9 1983
Post #621794 29th Jan 2022 4:33pm
number76
Thanks.
Out of stock.
How long ago did you buy your replacement lens please?.
Might have to try AliExpress or the like i guess if they are not stocking them anymore.
Did you get it your lens on and done?.
Cheers. 2014 L405 3.0 V6 Autobiography Santorini Black 49k
Post #621798 29th Jan 2022 5:03pm
Pendle
I bought it in Dec 2021
As far as replacing it ! You can believe all you read on this thread
My conclusion: having done the job it looks ok to a casual observer but I know that it is not quite right! Ebay here I come for a secondhand complete lamp cluster L405 SV Autobiography 2016
Previous:
L322 Vogue SE 2011
Mazda MX5 1999
Fiat X1/9 1983
Post #621802 29th Jan 2022 5:51pm
gqii4you
United States 2015 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Any update> How did it turn out?
Post #623908 16th Feb 2022 5:07pm
Pendle
Hi gqii4you
Well as I said before "my conclusion: having done the job it looks ok to a casual observer but I know that it is not quite right!"
So off to ebay and found the exact unit, fitted it, and no lights will work at all on the ebay unit! So I either have a duff unit or I am missing something, I will sleep on it and get hold of a mate with a bit more electrical savvy than me to help.
Watch this space!
Mike L405 SV Autobiography 2016
Previous:
L322 Vogue SE 2011
Mazda MX5 1999
Fiat X1/9 1983
Post #623989 17th Feb 2022 2:27pm
your 2016 should have the old style lights so have you replaced with the newer 2018 style ones?
genuine 2018 style lights will not work on the 2013-2017 FF's unless you re-pin the connections or get an adaptor cable.. ... - .- -.
Post #623998 17th Feb 2022 3:43pm
Pendle
Hi Stan, previous owner upgraded the lights, I broke one and found identical replacement, all codes are the same, but it does not work. Production date of previous one was 22/11/2019, 18MY. SVO EC. NON WORKING UNIT : 13/01/2020 18MY SVO EC
I have therefore not tried to re cable as existing should match??
Any thoughts?
Mike Pendle L405 SV Autobiography 2016
Previous:
L322 Vogue SE 2011
Mazda MX5 1999
Fiat X1/9 1983
Post #624003 17th Feb 2022 4:43pm
JCW
The re-pinning is usually done on the light unit, not the loom from the car - so you’ll need to re pin your new light unit - it’s a fairly simple process, there’s a ‘how to’ on here somewhere…
Post #624006 17th Feb 2022 5:19pm
JCW
…here’s the re-pin you’ll need to undertake, the wires can be pulled out once you remove the red locking tab from the connector. Be sure to label the wires first, as they’re all black! Thumbs Up
Post #624007 17th Feb 2022 5:24pm
https://drive.google.com/file/d/1V3-kRndh4...sq1qX/view ... - .- -.
Post #624008 17th Feb 2022 5:26pm
Pendle
A big thank you to all of you that posted here.
Finally I went to a second hand unit! Re wired the lamp as per Powerfuluk
If you want advice the please contact me here or PM. The tricky bit is releasing the pins! L405 SV Autobiography 2016
Previous:
L322 Vogue SE 2011
Mazda MX5 1999
Fiat X1/9 1983
Post #624487 23rd Feb 2022 11:56am
FF777
I'm in the process of changing the lens if anyone is interested
So far I have removed the old lens, it is plastic welded but very brittle so snaps off easy but leaves pieces in the groove which the locator ridges for the new lens sits in.
I'm going to bore out the grooves next I will keep updating
The lens from powerful are good quality/clarity but doesn't line up 100%
Post #625171 2nd Mar 2022 7:37pm
Page 2 of 3 <123>
