Home > Technical (L322) > Updated: Does a knackered BT module screw the whole system?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
My BT module got wet (its a D4 upgrade one) and now the screen just has the LR logo and nothing else.
Codes said optic message missing, so I assume because the BT is broken, the rest wont work?
Am i right (for once Rolling with laughter )?
Post #624176 19th Feb 2022 4:00pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Yes, when mine went the whole AV system wouldn't turn on
Post #624180 19th Feb 2022 4:33pm
philip1972
Thank you Thumbs Up
Post #624187 19th Feb 2022 7:13pm
kezbo1981
You can get a fibre optic joiner thing on eBay pretty cheap which allows you to do away with the Bluetooth module if you want to test the theory.
Post #624192 19th Feb 2022 7:42pm
philip1972
Ordered Thumbs Up
Post #624193 19th Feb 2022 8:25pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Dont expect it to cure the issue pal
Post #624226 20th Feb 2022 12:57pm
philip1972
What do you think the issue is?
Any pointers much appreciated.
Post #624227 20th Feb 2022 12:59pm
bembo449
Could be anything pal , over complex system that LR insisted on using ,makes it unreliable and difficult to nigh impossible to diagnose , mine is doing much the same but nothing i tried with the optics made a difference, im ripping mine out and fitting android from scratch, i hope the loop works for you , by the way you can try looping it to test it , youtube ' range rover atereo fix , its easy to try and free
Post #624228 20th Feb 2022 1:03pm
philip1972
I have just been out and re fitted the BT module....nothing.
So I tried a homemade loop and everything came back on. Still the odd crackle and pop from the speakers, but nowhere near as bad as yesterday. In fact, a bit of fiddling with the loop tube I used and it was OK again.
When I moved the loop I made it crackled again, so I think that is because the light doesn't quite meet up 100% unless I hold it straight, which is no surprise as its an old fish tank pump tube with a slight curve.
So a proper loop might be OK. If not, I will be looking out for your thread on how to change the system!!
But i am hoping its all OK, as I have not had any issue at all with it until it got wet. (The BT module is toast though, it smells burnt. No biggie for me since I haven't ever taken a call on it anyway).
Post #624232 20th Feb 2022 1:20pm
bembo449
Yay , result , at least you know for sure pal , order a BT unit now ??
Post #624233 20th Feb 2022 1:22pm
philip1972
I probably will, but I want to make sure that there is no more cracking when I fit the new bypass loop, which should come tomorrow (Amazon deliveries in France are not reliable).
I suspect the amp got wet/damp as well, but is slowly drying out, hence the crackling)
Post #624235 20th Feb 2022 1:25pm
philip1972
Just to update in case it ever helps anyone, I received the fibre optic loop bypass thing today.
Fitted it and all is well in the world of stereos Thumbs Up
Post #624370 21st Feb 2022 8:41pm
bembo449
Great stuff 👏
Post #624372 21st Feb 2022 8:54pm
