![]() | Home > Technical (L322) > Running a Cable Front to Rear of car? |
Has anyone got any tips for running a cable from the glove box to the ICE in the rear of the car?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
yes...
Cool, thanks. Does it go under the rear seats OK? I've not had the trim off there before...
dont go under the back seats but to the side under the trim. ... - .- -.
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Dan, I ran the aux in cable from the boot to the centre cubby box, basically took the wires behind the trim that hides the subwoofer, lifted the side trim for the seats out of the way, iirc, it just lifts out, then tucked them under the plastic trims for the weather seals, B pillar then in my case, tucked down under the gap where the carpet meets under the seat, but you could continue it to the kick panel trim then into the glovebox that way.
I ran my harness in the OEM locations when I retrofitted the nav. If you pull up the sill trims you can get to platic nuts which hold the covers over the cable conduits. If you really want to go OEM, remove the front seat to use the conduit to the console. And in the back, the wiring runs up and under the side trim - as Scarey said.
