| Squeaks.. what would you do? | |
Hey guys.. I am so close to getting my 4.2 SC driving.
I'm just about to fix an oil cooler connection leak.. then technically I can drive it.
But.. there is some awful squealing from the engine. I'm not sure if it's a chirp or a squeal.. which I believe is significant on these engines, as there was a TSB for "chirp" related sounds lol. Anyway, this one is on 162k miles, so I guess that would have been addressed?
Also... while I was in under the car, with tray off I had decent access to the belt/pulleys.. I unloaded a pretty hefty amount of belt dressing on there, and the sounds went away. Perfect, I thought. Stopped engine for a few minutes, and when I restarted the sound was back..
So, what would you do? Time to just bite the bullet and replaces belts? I guess my main concern is that I replace the belts and it turns out to be a pulley. Considering it's (allegedly) a pig of a job, do I just do pulleys also, while in there?
FYI - It sounds like this video..
https://youtu.be/AEUe6uKxTv8?t=9 (07) 2007 3.6 TDV8 L322 - 135k miles.
(05) 2006 MY Supercharged L322 - Zambezi Silver on Jet Black - 162k miles.
** Smiles per gallon - never forget **
