Home > Maintenance & Mods (L322) > How To: L322 Full LED Interior/Exterior Upgrade - Full Guide
Page 1 of 3 123>
garyRR
So, after searching the forum, I actually found very little on the topic and there are some absolutely nonsense videos out there on how to change the bulbs (*cough* Powerful UK *cough*).
So, I'm writing you a guide on how to upgrade all of the following lights to LED and will add each one to this as the parts arrive, explain how to do it and the part and why I chose it.
**A WORD OF WARNING** where possible, buy LEDs from brands you've heard of. My previous experience is that custom designed retrofit units are generally pretty decent but I cannot stress enough how much to avoid unknown brand LED bulbs - the price might be tempting but all they ever do is start playing up after a while. Good LEDs will last the life of the car so, invest where possible.
For my W5W T10 bulbs (for which 11 are required in my chosen set up), I chose the Philips ones. A well known brand and I previously fitted these bulbs on my Mercedes - after 4 years they had never given me a problem. The bulbs also dim. They are not Canbus compatible so, are for interior use.
1. Convenience lights (front of vehicle, lower dash)
2. Cabin lights and reading lights (in the roof)
3. Footwell Lights
4. Boot Lights
5. Door Puddle Lights
6. Glove box Light
7. Mirror Puddle Lights (Canbus)
8. Numberplate Lights (Canbus)
9. Reversing Lights (Canbus) (tbc if I will do this or not)
10. LED Comfort Lighting Retrofit (like the new RRs have). I've just done this install as well and a full write up. See my article here, if you fancy doing this too: https://www.fullfatrr.com/forum/post624201.html#624201
Difficulty: Easy
Tools required:
- plastic trim removal set
- flat blade screwdriver and clean tea towel
- microfibre cloth and interior detailer (for wiping your fingerprints off once you're done with each lamp, if you keep your car as pristine as I do)
- Insulation tape
1. Convenience Lights (2x W5W/T10) (5 minutes)
These will take you less than a minute to change each. It made me laugh when some videos suggest taking off side trim etc to get to them.
There is a light in each side of the dash. They're kept in place by a horizontal clip on the left and right side. Grab one of the plastic trim removal tools and simply lever it where the clip will be. The light will pull right out. Remove the multiplug, twist the bulb holder anti-clockwise and swap the bulb over. Plug back into the multiplug to confirm it is the correct way around (Philips logo facing down) then secure the bulb holder again and push the light back into place.
Repeat on the other side and you are done.
I chose the Philips LEDs for steps 1 and 2 because they're ultra reliable, not too bright and these are the units where there aren't LED retrofits.
WRC 681681 Philips X-Treme Ultinon Ledx2 W5W 12V https://www.amazon.co.uk/dp/B0759MBSQB/ref...&psc=1
2. Cabin lights and reading lights (6x W5W/T10) (5 minutes)
These take no longer than 2 minutes each for the front and rear light clusters.
Once again, grab your plastic trim tool and this time, begin levering in the locations marked in blue, working your way inwards. It will reveal the two metal clips holding each unit in - now simply just lift it out.
There's 3 bulbs in each unit. Just twist each bulb holder, pop in the new LED bulb, switch the light on and check the bulb is the correct way around, move onto the next one. Once you're done with the unit, push the forward end into its holder then push it back into place on its clips.
Massive improvement!
Now move onto the rear. It's exactly the same as the front - this photo really shows the difference in the light.
3 and 4. Footwell Lights and Boot Lights (5x retrofit light units OR 3x 28mm festoon, 2x W5W/T10) (10 minutes)
These steps are easy - they're all the same light unit, if you've bought the retrofits. If you've bought bulbs, the boot light and the two footwell lights are a 28mm festoon and the two tailgate lights are W5W/T10. I chose the LED retrofit units because, i wanted the boot lights to be as bright as possible.
If you want to save yourself a tad of cash, you can use one of the tailgate light units and utilise the spare Philips LED bulb you have and move this unit to the boot light, meaning you only need to order 4x retrofit units [two for tailgate, two for footwells]
All these lights remove and install the same way and all are direct retrofits.
Firstly, i find the multiplug fits better by slightly bending the pins in the retrofit units to better align with the plug. This takes about 10 seconds per plug. Just follow the below photo - put your screwdriver 3/4 the way along the pin and bend towards the shorter side of the socket.
With that out the way, let's move on to fitting.
I'll start with the tailgate. All lights have a notch in either side to put a screwdriver in. So, do just this and the lamp pops out.
Now just unplug and plug in the new lamp (with your freshly bent pins):
Looking better already:
Repeat for the other side:
Now for the boot light. Exactly the same - screwdriver in the notch and pop it out.
Now time to move on to the footwell lights. Screwdriver in the notch and pop it out, unplug and plug in the new unit:
You'll notice my pedals have magically changed from rubber to aluminium. These were also fresh in my delivery so, i fitted these at the same time (5 minute job)
Done!
5. Door Puddle Lights (2x W5W/T10 for Rear Doors and 2x Retrofit 'Range Rover' logo projection lamps for Front Doors) (3 minutes)
For this bit, I chose a retrofit part for the front doors, an LED projection lamp of the Range Rover logo, which gets projected onto the floor. This wouldn't be possible for the rear doors because on the L322, the position of the lamp and how wide the doors open mean the logo would get projected onto the car body.
(The two wires aren't actually needed. They come in the box, as these lights are designed for several vehicles. The light units themselves are just plug and play - no 'filing down' of plugs here!)
First, the rear doors (however, all lamps are exactly the same and are removed in exactly the same way). Use a plastic trim tool on the edge facing away from the car. You don't need to use any force here - the light will pop straight out. Now, just swap the bulb with one of the Philips LEDs. Correct fitment is the Philips logo facing the lens.
Looks great!
Now, the front doors.
The lamps are the same and remove in the same way.
You can see side by side that the retrofit unit is pretty much identical and well designed.
Simply just unplug the old light and plug in the new one. The lights are set up directionally (for left and right) so, check the light against your hand that you have connected the correct lamp for the correct side.
Now just pop back in. Ta da!
WOW
(The lenses rotate, if you want the logo in a slightly different orientation)
They look fantastic!
6. Glove Box Light (1x W5W/T10 [2010-2012] or 28mm Festoon [2006-2010]) (15 minutes)
This one is a bit fiddly. You need your T20 Screwdriver and a plastic trim remover (do not use a Screwdriver. The plastic in this area is thin).
The bulb varies on vehicles. 2011 onward vehicles have a W5W (such as mine so, another Philips bulb). 2006-2010 vehicles either have a 28mm festoon bulb or the W5W like the newer cars so, check this before you replace this bulb.
Firstly, remove the 4 screws in the roof of the glove box.
Next, remove the 4 screws behind the glove box, around the fuse box.
Now, use the plastic trim tool to gently pry both of these locations and the glove box unit will unclip. Do this gently - let the plastic of the trim tools bend and not the glove box!
Gently drop it down by about 5cm and this will give plenty of space to disconnect the glove box unit light.
Now for the fiddly bit! Gently unclip the unit. It has 2 small clips on each side. Be careful because there's a metal contact plate, spring and bit of white plastic which could all go walkabout. You now have free access to the bulb. Replace it with the LED bulb and check operation. If you're using the Philips bulbs, it's logo facing down. Then you will need to fiddle around getting the on/off switch to connect back inside its grooves inside the unit. Be patient and keep trying.
Now time to put it back together in reverse order. To re-clip the glove box, use some gentle persuasion. Hold the glove box in place as you return the top 2 screws by the fuse box then, just screw everything else back together and check the alignment of the glove box when closed. Adjust if necessary.
7. Mirror Puddle Lights (2x retrofit units) (15 minutes)
Here i fitted retrofit units, as they already have the built in resistor to prevent a canbus error. No fiddling around needed here, just straight swap!
There's a slight design difference between new and old so, follow carefully:
Start by using a screwdriver to unclip the lens on the light unit. Work your way around as to not break the clips. The lens removes first:
This then reveals the bulb unit:
Now, insert the screwdriver on the tab and the unit just lifts straight out:
Next, rotate anticlockwise to remove the bulb holder and remove the bulb:
Now plug in the new LED retrofit unit (red on the unit corresponds to yellow on the car) and check operation (lock car and unlock. Light should turn on). One of my bulb plugs was fairly corroded and i had to leave it soaking with electrical cleaner for 10 mins.
Once this is sorted, you want to tape it up, to prevent any stray pressure washer jets (would occur when spraying into the mirror glass) ingressing to the circuit, tape it all up with electrical tape:
Now push the wiring in the mirror (with the old bulb holder to the back of the mirror as not to foul the mechanism) and put the unit in place. Be warned!!!!! !!Once properly secured, you will hear a *CLICK*. The unit is not properly secured until you hear this sound. Gently press around the unit until you hear this noise.
Ta da!
8. Numberplate Lights (2x Retrofit units) (5 minutes)
I chose retrofit units here because these lights also run on the canbus. The retrofit units are actually especially clever in their design -> they incorporate a light lens with a festoon fitting, to pick up the power feed from the car. The retrofit units are directional and come with stickers over the lens identifying which side they go on.
This job is easy. Open the tailgate and locate the notch for a screwdriver on each lens, insert the screwdriver and remove (taking note of the orientation):
Now just swap over with the LED units:
Now turn on the car side lights and check for operation:
Look great and not overly bright!
Hope this helps and inspires others to do the same
 2015 Range Rover Autobiography 4.4 SDV8
Post #624112 18th Feb 2022 7:10pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Excelent start! Thumbs Up The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #624125 18th Feb 2022 8:35pm
kevinp
Watching with interest. Wanted to do mine for ages but have been wary about cheap led's.
Post #624131 18th Feb 2022 10:11pm
DrRob
Nice Thumbs Up Bow down
Got a link to the bulbs? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #624140 19th Feb 2022 9:16am
garyRR
Have added the link in the description. 2015 Range Rover Autobiography 4.4 SDV8
Post #624142 19th Feb 2022 9:26am
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Looking forward to next instalments Thumbs Up
Post #624230 20th Feb 2022 1:08pm
garyRR
If anyone fancies this, one of yesterday's projects was installing night time LED Comfort lighting. I've done a full write-up and how to guide:
The lighting kit: https://www.amazon.co.uk/dp/B09DYN7FJZ/ref...&psc=1
The Nextbase hardwire kit (it's actually better than the others on Amazon because the positive and ground cables are separate otherwise, you have have to cut the connectors, remove sheath and then put on new connectors): https://www.halfords.com/technology/dash-c...59302.html
Post #624234 20th Feb 2022 1:24pm
garyRR
Now added how to do the glove box. 2015 Range Rover Autobiography 4.4 SDV8
Post #624344 21st Feb 2022 6:14pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
like it Thumbs Up 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #624345 21st Feb 2022 6:42pm
DrRob
Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #624359 21st Feb 2022 7:55pm
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Thanks for posting. A number of mine are flickering - Philips now on order, thanks for the link. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #624363 21st Feb 2022 8:12pm
G3BML
Scotland 2010 Range Rover Vogue SE TDV8 Santorini Black
Going to order a load of the Philips w5w bulbs tomorrow.
What’s you thought for the footwell/door/boot/tailgate bulbs?
Post #624381 21st Feb 2022 10:28pm
garyRR
I have ordered a load of retrofit LED units for the footwells and projection lamps for the doors, which project the Range Rover logo onto the floor, which will look very smart.
This is for several reasons. The footwell lights are the same as the boot lights and I want the boot lights to be super bright - makes it especially handy when loading or hitching trailers etc in the dark. If the two front footwell lights are too bright, I will be fitting the Philips bulbs - hence waiting before I post that part of the article.
For the door lamps, I bought some of the same style projection lamps for my Mercedes at the time - they were dirt cheap so, i bought a spare set in case any ever failed. I had 1 fail in the 4 years but it was actually the lens which failed and not the LED (basically they're all the same unit and they have a stencil sticker inside the lens for whatever is to be projected onto the floor. The sticker had somehow creased itself and so the Mercedes logo also appeared with a crease in it. The LED still worked fine) Because I deliberately had spare inside the garage, I just swapped it over.
I'll post the guide and all the pics as i do it all then you can make your own decision on which lights you want to fit where and links to any parts I bought.
The Philips W5W bulbs will fit all of the footwell, door and boot lights so, you can just blitz the interior with Philips bulbs if you like. 2015 Range Rover Autobiography 4.4 SDV8
Post #624382 21st Feb 2022 10:43pm
garyRR
Now added door puddle lights!
If anyone wants a kit of the projection lamps for the front doors, I have a spare. £8 and I'll pop in the post. 2015 Range Rover Autobiography 4.4 SDV8
Post #624853 26th Feb 2022 8:23pm
V8rumbler
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Ipanema Sand
Great write up 👍🏻 2007 Vogue TDV8 in Stornoway Grey with Jet interior NOW SOLD
2011 (12MY) 5.0 S/C AUTOBIOGRAPHY ipanemaSand with Jet Interior
Post #624894 27th Feb 2022 12:16pm
Page 1 of 3 123>
