![]() | Home > Technical (L322) > Intermittent heating |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1051 ![]() ![]() |
It is a common issue we seem to be having, I'm getting the exact same thing. Heat on the driveway go for a test drive lose heat I'm now back on the drive with the engine off but ignition on heat selected to max fan speed at lowest setting to run the aux heater motor and after 10 mins sitting here iv got heat again.
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
Yep, same as mine. Sometimes I wish I had a Diesel or FBH, as I'm sure it would be easier to sort |
Well it's time to call it a night I had cabin heat so went around the block for the hopefull test drive.......lost heat. Pull up on the driveway contemplating life the universe and range rover air locks.
Final thoughts and observation from the last few hours, iv bled and bled this like every one else, air is getting into the heater matrix causing it to air lock. I previously used low pressure via a hose to back fill and flush any air out I did this before I swopped out my leaking thermostat modified 80 degree type. Iv fitted a standard type and refilled with coolant as I had a very week mixture of coolant in there but didn't use the low pressure hose because I don't want to lose all the new coolant.
landy95 Member Since: 04 Aug 2021 Location: West Midlands Posts: 86 ![]() ![]() ![]() |
Would it be worth trying a vacuum coolant filler about £40 on ebay, it should at least eliminate air locks, you will also need a compressor.
Yep I have both all ready, the trouble is the system has to be completly drained for them to work......if I don't have any luck it's what I will be doing next |
Thought I had this sorted after a test drive yesturday I still had heat, yippee then whoosh a hose I hadn't fully tightend came off the heating valve and dumped all my coolant. Wife to the rescue with 15 litres of hot water, I was local. Refit the hose refill, bleed drive home park it and leave it.
You have my sympathy, It's just such a pain. I'll try mine again later.
Well the vacum fill didn't work, it did get a lot of air out and it did refill it just didn't get all the air out so was still airlock somewhere. Wouldn't bleed out or anything so went old school removed the stat and drilled it refitted that at least allowed me to run it up to temp and bleed the thing properly good heat on the driveway no heat few minutes into test drive heating system air locked again |
Well today's action on the cooling and heating system led me to remove the new stat and bore scope the water pump turn by hand and confirm the impeller is good as is the rest of the water pump so I didn't need to swop it out. I then refitted the old housing from the low temp mod minus the stat . A huge amount of time checking bleeding checking again.
FJ12Jagmen Member Since: 25 Jun 2020 Location: Danbury Essex Posts: 77 ![]() ![]() ![]() |
I have the same problem, is it the same valve in a 2007 3.6 TDV8? |
It will be the same valve. However you will probably have another one in line, as yours is the diesel model & a fuel burning heater. Therefore best to check both of them. |
Thanks Highroller |
boy1der_uk Member Since: 09 Jan 2024 Location: Bradford West Yorkshire Posts: 15 ![]() ![]() ![]() |
Did anyone get to the bottom of this issue as I have something very similar, previous owner had a coolant leak in France and spent a fortune on LR bits to get it back home, and then even more back in UK, I bought the car few months ago and noticed warm air then cool air even with the temp up to the max. Car has just been in a friends garage for a big service and preventative maintenance, belts, pulleys alternator, oil cooler gaskets, pipe o rings and he’s checked the hoses encase some are crossed up, but he couldn’t find anything, apart from the coolant fan been left unplugged from all the coolant work but still the heater issue stands, it been beld up really well but still the heater just goes cold.
