![]() | Home > General > Advice/help needed with OBDII |
| Ludzy Member Since: 27 Oct 2010 Location: Leicester Posts: 191
Where can I get a full list of all the fault codes for L322 RR? My OBD reader arrived over the weekend and I have afew codes come up
Sorry for the bump |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
this any good ludzy..
Already looked there. Only codes beginning with P0xxx
But it's running abiit rough. Acceleration feels different. No misfire tho. Idle engine noise sounds different aswell. I had the "reduced engine performance" msg come up twice last week on the motorway. And last Monday the engine just cut out at them lights without warning. Started fine straight after tho. Cars been fine very since but as mentioned it does feel slightly different. I need to get it sorted aswell before we take it on holiday and i gotta get it serviced. my reader gave these codes which I was not expecting. I thought it could be the MAF or pipes but after these codes I'm stump.
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865
do you know any one with autodata as that will give you the codes....i have it but the pc its on has crashed at the mo if i get it working soon ill let you know what they are "RANGEISM WILL NOT BE TOLERATED"
| letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854
Maybe different OBD software will give you the same faults but with different codes. No pro here but i have googled 3 codes in the past and all come up on first page with description, tried yours which did not. If you had reduced engine performance come up then there may well be other codes that OBD wont read, your need testbook etc.
Cheers all
| All times are GMT |
