![]() | Home > Technical (L322) > Venture cam cradle voltage |
Blubberman Member Since: 11 Nov 2010 Location: South Wales Posts: 39 ![]() ![]() ![]() |
Hi ,
hi bubberman, if you have been through this post you will find that i have brought a number of these venture cams back to life, i would love to see inside one as i have never had to cut one open, did you just run a craft knife around it |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
Strangely enough, my venture cam now shows it's charging after not doing anything since I got the car 5 weeks ago. The funny thing now is that it says it's charging, and has done so for hours, but when I take it out of the cradlea nd switch it on, it only work for about 5 seconds and switches off again? When I put it back in the cradle, the ring around the power button comes on for about 5 seconds and goes off again. All the while the camera is hot to the touch?
sounds like the cells have changed polarity, give it a jump start with 12v if nothing 14v dont go mad or you will blow the board up in side... V8 facelift Range Rover Autobiography 22" wheels.
To open up the case of the venture cam , just lever it apart gently with a screwdriver . The case is held on by a bead of RTV sealant to make it watertight , so opening it up will break the seal so you will either have to reseal it ( probably not a good idea to use silicone sealant due to the acetic acid it contains which may corrode the circuit board) .
oh well , that didnt work , good job I am better with electronics than forums |
hi, you have miss understood me, of course dont reverse the power to the unit, yes something would pop. dont mess around with the cradle.....just the cam unit it self...
Hi Daveo ,
duplicate photo deleted |
you have the image command around the wrong way....[img] then [/img] V8 facelift Range Rover Autobiography 22" wheels.
Cheers Daveo , think I am starting to get it now
Docking Station
