Home > Technical (L322) > Suspension Issue
Old Barty
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Suspension Issue
Good Evening All, Have had my 3.6 Vogue now for some 6 months and early on , due to messages and having the fault codes read, My local garage have replaced the 2 front sensors ( which were aftermarket units) with new OEM parts. I have had no problems until over the last couple of weeks and being paranoid so having the 4x4 screen on all the time , I have noticed that the Red markers (Front ) on the 4x4 screen have been dancing up and down slightly away from the datum line -- Then after a while they settle down and stay put.
Well today I was going along a dual carriageway at about 80 mph ( oops ) and I got the dreaded 'Ping' and suspension fault , max speed 30 on the dash. I chose to ignore it as I was in a hurry and kept going, the suspension then lowered itself and then I got the message 'Raising' and everything went back to normal height and it has been OK all the way home.
When I got the Fault message the display showed it was the front sensors that were out of line --one high and one low !!!
As both front sensors have been replaced, I am starting to think, could it be the Suspension control module ?
Has anyone out there had anything similar ?
Best regards.
Post #624429 22nd Feb 2022 5:17pm
