![]() | Home > Technical (L322) > Deployable side step |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 300 ![]() ![]() ![]() |
On mine, I have them greased every service. Apparently they can get clogged and jammed with dirt.
Whussain5 Member Since: 18 Feb 2022 Location: Wakefield Posts: 15 ![]() ![]() ![]() |
Brilliant thanks Ivan I'll take it off tomorrow and grease it up to see if that helps
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
It will work for longer if it`s clean, putting a lot of grease can hold more dirt? using a good CRC silicone spray and not WD40 will help? |
I shall do that. Thanks for the advice |
Adrian 15 Member Since: 14 Feb 2021 Location: Norfolk Posts: 39 ![]() ![]() ![]() |
I had the same issue a few days ago, I gave the hinges a good flush with WD40 and they work again and I intend give them a good grease up or maybe looking at fitting a grease nipple. Range Rover Vogue SE 4.4 TDV8 |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I think fitting grease nipples would be a great way of sorting the lubrication issues with these. Filling them with grease would help keep the dirt and corrosion out.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 778 ![]() ![]() |
my experience of the brackets on these suggests that they're not particularly strong and the design doesn't look as if its nipple friendly.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1411 ![]() ![]() |
Try this
When I get a chance I will have a look about the possibility of grease nipples, if brackets are really unfriendly you could tig a nut or something similar to mount a nipple or even drilling a hole half way through the pin and then drilling again at right angles.
