Home > Maintenance & Mods (L322) > 2nd Battery |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3058 |
do a search on here. there are several who have done their own. |
28th Feb 2022 12:50pm |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 |
Today is Monday, I fitted this kit yesterday Sunday, with a 110ah battery into the right side towball void under the floor.
28th Feb 2022 10:13pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
Had a look at that kit and it's a fair price for what is included. One thing you might want to consider is lifting the loom out of the well and routing it up and over the wing fusebox, I did this easily. My concern was the battery could possibly move over time with vibration and bumps then wear through the insulation. 2007 TDV8 VSE
1st Mar 2022 3:23am |
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 92 |
looks good, have got a split charger system on my Disco for the winch but that uses an ignition controlled relay as apposed to voltage sensing (as in that kit) so would need a suitable pick-up point on a fuse box if I went the same way (usually its a system that is 'Dead' during the engine start but then becomes 'live' once the engine is running)
1st Mar 2022 3:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34916 |
from our wiki,
1st Mar 2022 3:29pm |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 179 |
Easy to do
2nd Mar 2022 8:18pm |
