![]() | Home > Technical (L322) > Propshaft carrier bearing |
| hotpotatojr Member Since: 05 Oct 2021 Location: Blackpool Posts: 71
Hi,
| kenneally_mark Member Since: 09 Jun 2021 Location: Cork Posts: 74
Thanks for the reply.
P/N from my research should have been TVB500400 - this was correct for my 2011 4.4 TDV8; I'm not aware of any differences between the 2012 model.
Ahh I get you. I've found one with that part number TVB500400 so I will order that and hope and pray it works! Thanks for your help & responses. |
No problem, just make sure it explicitly states 30mm internal bearing diameter - I ordered one with that part number and had to return as it was 35mm (incorrectly listed as opposed to the incorrect part number). |
Part ordered and photo taken of the diameter before it was sent so fingers crossed it all goes well. Thanks for your help. |
