Home > Maintenance & Mods (L322) > Adaptive Dynamics Fault - Replacement Link Wire
mjdronfield
So…. Got the good old Adaptive Dynamics Fault this morning.
Suspension is rock hard, made me feel sick on the bypass 🤣
I know it’s a known issue with the wiring on the front struts, so I’m assuming it’s that…
There seems to be a fix kit available, LR032839.
My query is whether this kit has more flexible wires in it, so shouldn’t fail again, or are the wires still prone to failure like the original ones?
This is helpful though…
https://www.fullfatrr.com/forum/topic54413...e+dynamics
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #624906 27th Feb 2022 4:26pm
kevinp
I suppose you could look at it that the original wires have lasted 10 years so the new kit should last the same?
I've just redone one of mine with some really flexible cable leaving a big loop in it.
Post #624914 27th Feb 2022 5:29pm
DrRob
I had a kit fitted by Glenrands and it now looks factory fresh. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #624915 27th Feb 2022 5:30pm
mjdronfield
Hoping it’s a simple fix.
Went a bit harsh all of a sudden… no error shown on dash…. Then failed MOT on leaking rear shocker, put 2 new ones on, and it was still the same really. That was Christmas. Not used it much, and then fault today, so I’m hoping once it’s sorted the ride will be back to being comfortable… wasn’t as harsh as it is now, even when I thought it was harsh.
Thinking it might not have been working right but no fault showing, but now wire has fully snapped and it’s showing the dash message.
I’ll inspect the wires and take it from there.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #624941 27th Feb 2022 9:55pm
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Kit is the same wires from what I could see. Fitted one a couple of weeks ago. Initially repaired the original but it failed again 6 months later so bit the bullet Thumbs Up
Cheers
MM 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #624947 27th Feb 2022 10:43pm
mjdronfield
Yeah. If it’s that I will just get it joined up as best I can and then order the kit.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #624948 27th Feb 2022 10:48pm
Range Rover L322
The replacement front ones are a slightly better design when I compared them. i cant remember what precisely but I noted at the time they were more substantial. I think the rubber maybe onepiece when before it was two.
It is worth doing the rear ones too, they are easily accesible just behind the back seats. Although they have less stress as no steering movement they were as brittle as twigs on mine (2012).
Good luck!... 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #624954 28th Feb 2022 12:13am
mjdronfield
Cheers for that. Saw those when the rear shockers were replaced.
Just been out to look… and if I were a betting man….
Looks like the other side has already had the fix kit fitted….
I shall order the kit…
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #624964 28th Feb 2022 10:04am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
let us know how it goes Thumbs Up 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #624968 28th Feb 2022 10:17am
mjdronfield
I also noted that the broken side didn’t have a gromit fitted, so each turn of the top would have pushed the wire directly…..
See if the fix kit sorts the issue tomorrow.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #625013 28th Feb 2022 5:43pm
GraemeS
Australia
I released the clip holding the wire to the body to give the cable near the cap more freedom to move less. I also rotated the plate below the cap so that the cable had equal freedom when the cap turned in each direction.
Post #625036 28th Feb 2022 8:42pm
mjdronfield
Fitted the new wiring. Fault has cleared from the dash and suspension no longer rock solid.
Perhaps it’s having rear shocks that weren’t at their best, and now had new ones around Christmas, but it’s still not what I’d call a magic carpet ride…. It corners level during normal driving, and you can feel road undulations. Could be as I said, being used to dodgy rear dampers…
I couldn’t get the grommet in the top metal cap though…. No matter what I did.
So for the moment, the wire isn’t tied back…..
Are they supposed to corner flat? At normal speeds?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #625082 1st Mar 2022 2:25pm
GraemeS
Australia
Mine stays quite flat initially but will start to lean a little on a long bend. I regularly travel a section of rural road that does an S bend over the top of a hill, starting at 100 kph then easing off a little over the crest. The vehicle is very steady, without lurching, understeer or oversteer as it changes direction through the bends.
Post #625116 1st Mar 2022 8:51pm
