Home > Maintenance & Mods (L405) > Best trolley jack for Range Rover
pld118
Looking for a low profile trolley jack with quick pump action that definitely will go under a low car but also that’s going to get the RR up to a good height (as high as possible) easily and quickly for changing wheels, fettling brakes, placing axle stands easily etc.
Recommendations welcomed - was looking at the SGS 3 TONNE LOW PROFILE HEAVY DUTY GARAGE TROLLEY JACK - that lifts to a height of 535mm but none in stock Rolling Eyes
Thanks
Post #625108 1st Mar 2022 6:59pm
Wk52RR
England 2003 Range Rover HSE Td6 Epsom Green
I’ve used the Halfords advanced 3 tonne for my last 3 range rovers. Also used on a bmw e92 335d and a Jaguar xkr. Fits under and lifts all cars really easily with a lot of control. Plus I believe it comes with a 3 year warranty. Can’t fault the jack and I think with a trade card I paid about £90 last year for it.
Post #625111 1st Mar 2022 7:09pm
pld118
Thanks very much Wk Thumbs Up
Post #625114 1st Mar 2022 7:30pm
pld118
Couldn’t use my Halfords trade card online and so got fed up trying (it keeps happening)… then decided on a 3 tonne SGS one at £119 but it’s not in stock and so….
Don’t know if it’s the best for a RR (time will tell) but… Just ordered a Sealey 3 tonne Trolley Jack with Rocket Lift - 3040AG …. after spending too many hours pontificating 😂
Got it for £148 incl delivery via an eBay 10% special offer and it’ll be delivered on 4th March. The lowest setting for the jack is 100mm and it will raise a vehicle to a max saddle height of 533mm so it should be good for raising the RR… and hopefully a lot quicker and easier than the pfaffing around I’ve been used to with my current pieces of kit… Fingers crossed it’s good 🤞
I’ll update when it’s been used….
Post #625151 2nd Mar 2022 4:37pm
pld118
Jack arrived today. It’s a monster and very smart looking. Reminds me of something you’d expect to see in a formula 1 garage Laughing
Never expected it to be so big but it feels like top quality and I’ve no doubt it will do everything the RR and our other cars throw at it. The Rocket lift feature is brilliant and reduces the number of pumps require to get the jacking pad in position. Comes with a good round rubber jacking pad too. Very pleased with this new toy. Thumbs Up
Post #625321 4th Mar 2022 2:17pm
mlambton
United Kingdom 2015 Range Rover Autobiography SDV8 Corris Grey
They look good. Apparently the 3 ton SGS ones are due in 3-6 weeks though the 2.5t is in stock and has almost the same height. Im still hesitating so just ordered the 2x6 ton stands for now - due Monday Smile 2015 Range Rover L405 SDV8 AB Corris grey
2010 Range Rover TDV6 HSE Narra Bronze sold
2006 Discovery 3 SE green sold
Defender 90 td5 sold
Defender 90 soft top sold
Post #625324 4th Mar 2022 3:53pm
BenRK
I use the SGS 3T Low profile jack on my disco 3 and range rover and it works perfectly. I use a solid block of Oka or something similar to protect the rubber pad on the jack and even out the pressure of the jacking points. Had it about a year and I am constantly swapping wheels so gets a really good workout and has been totally fine
Post #625325 4th Mar 2022 4:17pm
Merchy
A good tip for when you buy a new trolley jack.
1 Check to see if an overhaul kit ( including all hydraulic seals ) is available for the jack you wish to buy.
2 Buy a kit and keep it wrapped in thick black plastic away from extremes of temperature.
Otherwise you can end up with a failed jack that is only a few years old, and find that spares are no longer 'available' Bloody annoying when that happened to me. Censored
Post #625332 4th Mar 2022 5:16pm
mlambton
Very good advice Merchy...thanks 2015 Range Rover L405 SDV8 AB Corris grey
Post #625339 4th Mar 2022 6:01pm
pld118
Good tip Merchy Thumbs Up
It’s some piece of kit. The most susbstantial Jack I’ve ever used or am likely to use Shocked
Front near side wheel is 6” of the ground in this image and there’s plenty more height left for the Jack to take the car to. Frightened to take it any higher Laughing
Post #625343 4th Mar 2022 6:29pm
knwatkins
Is that a little magnetic wheel nut tray on the top? Very neat! Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #625366 4th Mar 2022 9:31pm
pld118
It is Thumbs Up
And this home made wooden L405 jacking pad that safely sits on top of the Sealey round rubber jacking pad is just the job:
https://www.fullfatrr.com/forum/topic62818.html
Post #625371 4th Mar 2022 10:05pm
