Home > Maintenance & Mods (L322) > 2007 rear wheel getting warm
tdv8rr2007
United Kingdom 2007 Range Rover Vogue SE TDV8 Buckingham Blue
Strange one, n/s rear wheel was hot to the touch the other day, suspected sticking pad / caliper so stripped everything down and found everything to be free, and the piston pushed back really easily. Parking brake all seemed to be fine and not dragging.
Found the rear pads had obviously been hot and that they had cracked so suspected that perhaps water had got behind the pad material. Rebuilt with new pads and all was well for a couple of days.
Noticed today rear wheel was slightly warm to the touch am I right in thinking this can only be caliper despite the fact it all seemed to be fine?
Am just asking incase anyone had anything strange with rear brakes before.
Post #625667 8th Mar 2022 9:39am
mjdronfield
Wheel bearing?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #625669 8th Mar 2022 9:53am
cass
could it be rust under the shims that the pads slide on?
Post #625676 8th Mar 2022 12:36pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Were the caliper slide pins moving ok? The upper pin has a rubber boot part way down that can swell and cause the pin to jam 2011 TDV8 Vogue SE
Post #625678 8th Mar 2022 1:02pm
mpirie
I'd still put money on it being a sticky calliper.
It may be that there's corrosion under the rubber seal that causes the piston to stay out when pressure's applied.
Mike
Post #625680 8th Mar 2022 1:48pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
The wheel bearing would have to be close to collapse to generate enough friction to warm the wheel.
100% it's the brakes. Check my project page for what I did. Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #625685 8th Mar 2022 2:45pm
tdv8rr2007
All valid points thank you! However both pins were free as anything, and i always take the shims off and thoroughly clean under them them when changing pads.
I did question regarding the wheel bearing but it isn't noisy and i cannot feel any play.
I suspect i will end up sticking a caliper on it this weekend and see if that cures it.
Post #625686 8th Mar 2022 2:47pm
mjdronfield
Ah, forget the wheel bearing then….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #625690 8th Mar 2022 3:15pm
If you don’t find anything else it could be the flexible brake hose at fault. They have been known to deteriorate internally and end up acting as a non return valve.
Post #625698 8th Mar 2022 3:46pm
tdv8rr2007
If i remember correctly the rears were done as a dealer recall approx. 5 years ago. I would be disappointed if genuine parts had failed in that time although its not impossible. Will stick a caliper on it and see if that cures it if not then I agree that pipe is indeed suspect.
Post #625699 8th Mar 2022 4:26pm
mpirie
If you see any black bits in the bled brake fluid, that would indicate if the flexi hose was breaking down.
Mike
Post #625728 8th Mar 2022 8:31pm
tdv8rr2007
Good point Mike! Have parked the Rangie up till the weekend till i can get a caliper. Will be interesting to see what comes out.
Post #625730 8th Mar 2022 8:37pm
DanRRL322sc
What was the outcome???
Post #632066 18th May 2022 7:50am
