Home > Technical (L322) > front suspension lowers
marcel911
Belgium 2012 Range Rover Vogue 4.4 V8 Java Black
Hi everybody.
When the car is not used (2 days) the front of the car lowers. Only the front. Air struts where changed last year .
Checked all the air lines for leaks. Nothing found.
Anybody has any ideas. Fault code C1130 .Front valve block seems ok no external leaks.
Post #625710 8th Mar 2022 5:58pm
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
Hi, I had a similar problem where the rear was lowering. Can’t remember if I got the same fault code but the rear offside sensor was not working so I changed it and it solved the problem. From what I can remember the whole of the rear of the car lowered because one sensor was not working, might be an idea to check the sensor to see if the wires are broken or not.
Post #625753 9th Mar 2022 7:38am
tj196443
Just remembered to add that once I started the car the rear end did rise up to normal height and only lowered when parked up overnight.
Post #625754 9th Mar 2022 7:40am
marcel911
It takes a while for the car to lower( 2days). I think it's an air valve that fails but I don't know which.
Post #625762 9th Mar 2022 10:31am
