![]() | Home > Technical (L322) > Another fuel burning heater problem. |
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
Rapid flashing of green on the remote indicates the battery is flat 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Have you tried re-pairing the remote to the FBH module, might need to be re-paired if the old batteries had gone totally flat. If that doesn't work, try putting new batteries in the Fob and re-pairing again. You could have got a dodgy 'new' battery. |
mrtidy Member Since: 31 Aug 2015 Location: Stockport Posts: 214 ![]() ![]() ![]() |
I hadn't thought the new batteries could be flat, I'll get some new ones and see how it goes, how do i pair the remote if I need to?
There's a 'how to' in the WIKI page |
Thanks I'll take a look . 2009 Vogue SE Zermatt silver |
New batteries fitted and tried to pair it as per the wiki and still no joy,might see if i can get a new remote. 2009 Vogue SE Zermatt silver |
Before you do that, try this method of pairing the remote, by removing the power lead from the FBH module in the rear compartment. See link below:
Thanks for that,just tried that and no change alas, I've got my eye on a remote on eBay, if I get that I'll try that and see what's what, if that doesn't work then might get another receiver and give that a go . 2009 Vogue SE Zermatt silver |
