Home > Maintenance & Mods (L322) > How To: L322 Full LED Interior/Exterior Upgrade - Full Guide
Page 2 of 3 <123>
GraemeJudge
2004 Range Rover Vogue Td6 Java Black
garyRR wrote:
Now added door puddle lights!
If anyone wants a kit of the projection lamps for the front doors, I have a spare. £8 and I'll pop in the post.
I'll be interested in a set of these please if still available
Post #624925 27th Feb 2022 6:52pm
Barkballz
Really nice write up - will be doing this for my self with your inspiration so thank you.
Assuming your second set of projection lamps have gone, do you have a link as to where you got these ones from?
Cheers
Post #625045 28th Feb 2022 10:44pm
garyRR
Have now added the guides for all lights! 2015 Range Rover Autobiography 4.4 SDV8
Post #625704 8th Mar 2022 4:52pm
DrRob
Did I miss the link to all the retrofit units e.g. number plate light?
Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #625705 8th Mar 2022 5:03pm
garyRR
Bow down
Links to the items are under each step heading. 2015 Range Rover Autobiography 4.4 SDV8
Post #625706 8th Mar 2022 5:30pm
G3BML
Scotland 2010 Range Rover Vogue SE TDV8 Santorini Black
A bit off topic, but where did you get the pedals from? Much nicer than the standard rubber/plastic ones! Thumbs Up
Post #625752 9th Mar 2022 6:44am
garyRR
£12 delivered. 2015 Range Rover Autobiography 4.4 SDV8
Post #625859 9th Mar 2022 10:05pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Good write up mate. I've been doing mine however the main interior light has caused me a few issues as it won't sit back in place properly any more.
Any suggestions mate?
Post #625872 9th Mar 2022 11:25pm
garyRR
Drop out the unit again and align the tabs on the unit facing toward the front of the car. Once these are aligned and the front of the unit is seated flush, pivot the unit into place (back of unit with metal tabs). Check the metal tabs are located correctly and then press firmly until the light unit goes back into place.
Don't remove then try and push the light unit vertically back into place. The front facing section must be located first then pivot the rest of the unit in. In the photo, the front section is clearly not located correctly. Also make sure the metal tabs align with the little slots in the trim before pressing firmly. 2015 Range Rover Autobiography 4.4 SDV8
Post #625873 9th Mar 2022 11:38pm
Bean19844
Cheers mate.
Is it pretty much push the back of the light in first then the front of the light with the metal tabs in.
Post #625876 10th Mar 2022 4:16am
Jambo
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Great improvement and really easy to follow steps. Thanks for producing and sharing such an in depth 'how to' Thumbs Up I'm off to order some bulbs now....
Post #625882 10th Mar 2022 9:43am
kevinp
Just a tip for getting the mirror puddle lights out without any damage to the old light if for any reason you want to keep them.
I used a stiff feeler gauge to get to the holding clip instead of a screwdriver and mine popped out nicely with no damage to the mirror. Thumbs Up
Post #640185 19th Aug 2022 1:53pm
Buie
United States 2012 Range Rover HSE 5.0 V8 Santorini Black
Re: How To: L322 Full LED Interior/Exterior Upgrade - Full G
You're a legend Gary. Thank you.
Post #713297 4th Mar 2025 4:08pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Just changed all the interior lights on my Vogue SE. Makes a really big difference, smartens up the interior and looks really good.
I didn’t actually realise how many of my bulbs were blown, so for £34 it was a very nice improvement.
I used this kit https://www.ebay.co.uk/itm/314226400293 which comes with sufficient bulbs to do all the inside. They importantly dim when closing the car and brighten when opening up.
Post #718824 30th May 2025 9:05am
jimbob292
Excellent write up, on the to do list for sure. Where did you purchase the retrofit units from, for the puddle, door & plate lights etc from?
Post #720133 21st Jun 2025 10:11am
Page 2 of 3 <123>
