![]() | Home > Technical (L322) > new rear discs and pads needed shortly - are these ok? |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
corrosion around hub and outer 'rim' and are 'squealing'
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6376 ![]() ![]() ![]() |
Brembos only fit the later cars AFAIK with a certain wheel type
no advice/comment with the info provided that was asked for? |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
nick they seem to be the right ones you dont have to have brembo brakes to have those discs ....
thanks ![]() its the calipers that can cause problems with some earlier models |
Dan any comment as you know the 'system' so well?
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Brembo supply aftermarket discs for lots of makes/models, not just the cars with factory fitted show-off Brembo calipers |
The 304mm disc 08.6838.10 cross refers to LR part SDB000470 which is for P38 Range Rover and Disco2
thanks |
Sorry, I was going to reply. Then, on the balance of things I decided not to. ![]() ![]() |
