![]() | Home > Maintenance & Mods (L322) > Parked for couple of month, handbrake stuck on |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3987 ![]() ![]() ![]() |
Try gently driving back and forth, it my free off. |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
You could try banging the rear drum to try and shock the shoes away from the drum.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Not sure what the set up is for the handbrake is it a handle with cables ? if so then try putting it in gear with the footbrake applied 1500 to 2000 revs then release footbrake do a few times forwards and reverse it worked for my p38 which had a similar problem also if it is cables on handle if you can get underneath spray the cable carriers with wd good luck |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3346 ![]() ![]() ![]() |
When you're trying to rock it back and forth, use low range too. Lots more torque without the revs |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Cheers guys, free'd her up eventually with the forward/reverse technique, just didnt like the creaking but all good now.
Glad you are sorted I cycle mine every week into low range same with the handbrake once a week also all the heater controls
