![]() | Home > Technical (L322) > DSC HDC / AIR SUSP INACTIVE |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
Reversing on a snowy incline yesterday, trying to park at a friend's, got a bong with the amber triangle ⚠️ and HDC / AIR SUSPENSION INACTIVE messages on the dash.
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 823 ![]() ![]() ![]() |
I am thinking its nothing to do with the suspension, that’s why the GAP cant clear it.
Your assessment is correct as far as the air suspension is concerned. There's nothing wrong with it. But it defaults at standard height once an ABS malfunction has been registered. I had the same when my PCV valve went bad.
Dropped the ABS module at the ECU repair shop today. As I needed the car and there was no way I would leave her on their street overnight (prime target for cat theft). Driving around without it is somewhat scary, mostly because of the feather light steering at higher speed...Hope they're fixing it today and to have it back by tomorrow.
Hi, where is the ABS module located RR 2005 4.4 petrol
Under the bonnet, in front of the driver, on the inside of the shock absorber turret. It's the black box with the wide multiplug bolted on the ABS pump. Will post a pic for you. |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226 ![]() ![]() ![]() |
Low Batttery perhaps
Nope, not this time. Battery is in great shape. Alternator as well.
Once more, it seems that nothing's easy with the L322 |
Got the replacement ABS module today. They said they didn't have time to fit (!) normally a 2 minute job for 6 bolts and 2 plugs (no coding needed according to them) and I would have had to wait till Thursday just for that... So I said the hell with it, I'll do it myself.
My garage was able to code the ABS module in minutes |
good to hear its fixed RR 2005 4.4 petrol
Any progress with yours?
