![]() | Home > Maintenance & Mods (L405) > 2014 RR L405 suspension lowering |
Sester Member Since: 20 May 2019 Location: Doncaster Posts: 92 ![]() ![]() ![]() |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2751 ![]() ![]() |
I assume that LR called the module the chassis module because as well as the suspension ecu it contains the CVD ecu which is powered by the 15A fuse 23. |
Thanks, I take it the one I’ve taken out (10amp) is the right one yes ? |
Good morning, so I’ve come out to my car and the rear of the car is fully lowered on both sides ?
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 300 ![]() ![]() ![]() |
More likely to be the rear valve block.
Oh….
It will be in the Workshop Manual which is available in the Wiki. Looks like it may be by the rear NS air spring.
Got the motor booked in !
Hi all sorry not fed back sooner.
Well, finally found the problem !!!
RutlandBoy Member Since: 20 Mar 2022 Location: East Northants Posts: 31 ![]() ![]() ![]() |
Hi,
If the car is slightly on the tilt/parked on an incline then it will often keep trying to level itself and gradually dump itself on the floor...
Thanks,
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 99 ![]() ![]() ![]() |
Sester can you not use one of these inline air hose couplers where you have the pinhole leak as an interim solution until a new tube arrives, just cut the tube at the hole and push both ends into the coupler, they are sold in a variety of diameters, must be available at your local hydraulics / pneumatics supplier, just identify your tube diameter..
