Home > Maintenance & Mods (L322) > 4.4 TDV8 Belt tensioner replacement
Page 3 of 5 <12345>
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Well due to Covid and time the dealer arranged for a local garage to carry out this task. so i am not able to do a write up. i know it was a full days job and they did take the front end off to gain good access (They have done them before and found this way better for them) it took the 8 hrs to complete in total. Also according to the manual from WiKi removing the front end avoids having to discharge the AC so you can split the pipe running across the front of the housing. this needs to be done to remove the housing of the fan so you can remove it from the top of the engine bay.
below is a pic of the main belt you can see it was on its last legs Shocked
I have to say the car is very quiet now i think there was more noise than just the squeal. I got back all the parts changed and some of the bearings are quite noisy but the plastic parts all seem to be in good order i am tempted to replace the bearings in them and sell them on!!
 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #582386 4th Feb 2021 5:55pm
mezo
United Kingdom 2012 Range Rover Vogue SE TDV8 Java Black
great write up - was just doing the oil cooler and happened to look down and notice the belt was running right at the edge. When i levered it up to take the tension off you could see the lateral movement in it. Once i got it off, on the back of the tensioner the housing was actually cracked.
Post #626089 13th Mar 2022 6:22pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
There's no need to split the AC pipe, just unbolt it from the fan shroud & there's plenty of flex in the rubber hose to allow the shroud to comeout👍
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #626094 13th Mar 2022 7:26pm
longd
John w wrote:
Hi,
adding this here as this seems to be the go-to thread for tensioner / belt replacement.
I'm replacing my belt and pulleys as the belt came off this week.
A couple of things that might be helpful to others.
- removing the airboxes is necessary, but not the upright plastic air tubes, they just need unbolting so they can be pushed out the way.
- it is easier to get the tensioner bolts out / in (especially the top left one) if you remove the top right pulley first. You can then clearly see them and get a hold of them (less risk of dropping them).
- it is possible to change the belt without having to remove the fan / cowling, and no need to drain down the cooling system, but you need a bit of patience.
In order to replace the belt with fan / cowling in place you need to:
- unplug the fan connector, unclip it from the housing, and feed it out of its location into the fan blades, gently pulling it through them a bit.
- You can then pass the old belt over the fan between the blade and the housing, which will also be in front of the cable too now. Getting the new belt in the same way.
- It is necessary to remove one bolt on the aluminium coolant tube located behind the fan, bolted to the front of the engine. This is necessary regardless of how you do it. Its an 8mm bolt, and a nightmare to get to with the fan in place, but doable. You are likely to drop this bolt, so stick a nail or something to the head of it once loose to make it easier to get a hold of (don't use too much glue as you will need to remove it later). Put a bit of card up the front of the engine from below to help guide it out when you do drop it, saves trying to find where it went multiple times.
You then lever the bracket forward a bit to get the belt between the bracket and engine.
Use the nail/whatever attached to the bolt to help you get it back in and the threads started. Then you can pull it off so you can tighten it up with a socket / spanner.
Hope that helps.
How in the name of god did you manage to get that bolt out with the fan in its place !!! It’s an absolute mare !! I reckon I’ll get it out but I honestly doubt it will go back in !!!
Post #626163 14th Mar 2022 6:20pm
JayGee
The 'chirp' on my belt is driving me mad. Had the lot replaced last year but think I spilt oil on it while topping up without a funnel. Tried everything to clean / degrease the belt in situ but the noise just comes back so may have a go at this. 2012 TDV8 Vogue (L322)
Post #626169 14th Mar 2022 7:25pm
Range Rover L322
I have had the belt tensioner mod done. The chirp started when it got cold in December.
I still have the chirp now. 10ÂşC here in the mornings on the car temp gauge. No affect to performance in any way.
. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #626194 14th Mar 2022 10:17pm
JayGee
Is there a 'mod' for the standard tensioner to stop the chirp? 2012 TDV8 Vogue (L322)
Post #626203 15th Mar 2022 8:23am
longd
John w wrote:
Hi,
Hope that helps.
Do you have to remove the fan belt to get the auxiliary belt on ?
Post #626225 15th Mar 2022 12:56pm
Smitch
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
Attempting this shortly but trying to find out where to do a partial coolant drain, the WM has this:
Is this hose above the transmission cooler and how much coolant will I need to drop?
Thanks
Post #626311 16th Mar 2022 3:06pm
longd
Without sounding like a Censored a partial coolant drain is gonna depend on how you you drain , I did a full drai no of the system and removed everything the first time I had the belts changed this time I have done it without draining or removing any of the coolant system. It is horrendous to do it as I have fat arms and big hands and space is limited . You can change the main belt and tensioners without stripping out fan etc . But if you want to change the small belt you will need to remove the fan assembly.
That oil cooler you have the picture from will be seen the second you remove the lower plastics beneath the engine bay from underneath the car
Post #626312 16th Mar 2022 3:11pm
Smitch
Thanks I’m doing it all including fan belt so it looks like I’ll do a drain from that point. Was just puzzled at what that box in the pic was had a suspicion but wanted to make sure.
Post #626314 16th Mar 2022 3:16pm
johnboyairey
just changed my water pump which meant belt off, and fan and shroud. its quite a big job, lots of hidden bolts. and getting the water pump off the front of the engine was tricky, as I had to make a bracket to allow me to hammer it away from the engine, without hitting the radiator. its all back, and running fine. (except the coolant level float has gone faulty. so get the warning etc.). he-he. one job leads to another!
Post #626327 16th Mar 2022 5:37pm
kevinp
This thread makes interesting reading. I've just ordered all the pulleys and belts to do mine. Just waiting for LR025988. Doing the water pump as well. I've gone for genuine parts. Trying to get rid of an engine speed related whine.
Anyone found a particular dodgy bearing in anything they've changed?
Post #626331 16th Mar 2022 6:58pm
johnboyairey
this guy, does the alternator, and takes the fan and cowl off, and does his pulleys, whilst the opportunity is there. the water pump is just 4 bolts, but its hard to prise it away... it needed a 'U' shaped plate bolted to the pulley wheel holes to allow tapping it forward. good luck.
Post #626336 16th Mar 2022 8:01pm
kevinp
Post #626337 16th Mar 2022 8:30pm
Page 3 of 5 <12345>
